Results 1 to 2 of 2
    evanselec's Avatar
    Shropshire
    Default FORD PANASONIC UNITS MUTE PROBLEM
    HI CAN YOU HELP WHAT IS THE PROBLEM WITHIN THE CV4T-19C107-GG GB GH TYPE PANASONIC UNITS
    WE ARE SEEING LOTS WITH THE STUCK ON MUTE PROBLEM HAVE TRIED MASTER RESET STILL SAME
    I AM LOOKING FOR INFO ON WHAT THE MUTE TRANSISTER IS AND ITS LOCATION ?
    A CIRCUI DIAGRAM WOULD HELP OR ADVICE ON THE PROBLEM
    MANY THANKS LES
    CAPS DUE TO BAD EYES NOT SHOUTING .
    Aug 2019
    Johannesburg RSA
    Hi. This is a very common problem on SYNC head units. Remove main PCB and turn over. You will find overheated components around Q201. Clean with flux and re-flow overheated area. For reliability fit flexible heat conductor between 5 pin regulator, Q201 and bottom cover. This circuit provides the 1.8V to the DSP chip.
  3. The Following 2 Users Say Thank You to MrRepair For This Useful Post:
    audiopoint (7th July, 2022), evanselec (7th July, 2022)
