Results 1 to 5 of 5
    Member dolphin123's Avatar
    Default How can I change ecu polo 2004 model,
    I bought a new ECU and I want to wear it. I need to follow the road Can you describe?
    help please
    soft code: 00061
    extra: vwzzz9nz4y238736 - vwz7z0d9902482
    wsc : 00078
    magneti marelli 4tv.GQ
    but the new ECU
    im*o'll correct the problem of how
    vag-com 704 how do I fix this problem
    Immobilizer III ECU Swapping - Ross-Tech Wiki
    or simply swap eeprom: from original ECU to new ECU
    france
    Default ECU polo
    hello,
    So to change your ECU Reprogram are your key and other codes, you change the EEPROM you take your old ECU and puts you in the newhello,
    DK Veteran agabna's Avatar
    hello
    for all vag immo type
