black1970 (5th February, 2023), enigmaelectroni (27th July, 2022), Sandeepa (28th July, 2022), YOUSSEF SL (6th September, 2022)
Second tip while desoldering.
A lot of the cheap Chinese wick are too tightly weaved for proper desoldering.
Open the wick up with your fingers and add some flux. Way better
Can't stop aging and this is life saver... annoying though
Mine didn't have it thought i had share the trick i found with others. The second magnifying glass being not fixed in my case makes things easier in a way to get better view
Hi M8, even for youngers....lens and microscope are a must have tools!!
Regards.
Chiptuning file services ,custom remaps, inmo off, egr off, dpf off, adblue off, flaps off, tva off, lambda off, speed limit, selective dtc´s deleting ,etc.
Worldwide assistance.
All brands, All vehicles, All files.
I think you missed the point.
i was using a single magnification lens (out of the box).
Then i found out that using two magnification lenses in series gave a much clearer image. That is what i share in my post.
I personally did not know about it and thought I had share for others to take advantage
