Results 1 to 15 of 15
    italy
    Default checksum correction on audi a3 marelli cluster show 999999
    please somone can help me with checksum correction for audi a3
    May 2016
    Try.................
  3. The Following User Says Thank You to naprawa5 For This Useful Post:
    fra69 (15th July, 2022)
    italy
    Quote Originally Posted by naprawa5 View Post
    thanks for help mate but still not working
    999999
    checksum incorrect
    anny other help?
    italy
    nobody?
    i see digiprog can fix it but i've other programmer.
    some help?
    levisdj's Avatar
    EcuLand
    Here is 0 km with chk fixed... set desired value with vcds
    italy
    Quote Originally Posted by levisdj View Post
    not work mate.
    still 999999.
    levisdj's Avatar
    EcuLand
    You know the old value?
    Test this one, if it does not work I dont have other ideas
  9. The Following User Says Thank You to levisdj For This Useful Post:
    fra69 (19th July, 2022)
  10. #8
    italy
    999999 on display
  11. #9
    Oct 2020
    Bulgaria
    Its not encrypted so find another good dump with same part number, correct mileage, write - if all ok, learn to car. done
  12. #10
    italy
    Quote Originally Posted by evgeny87 View Post
    my problem it's thet car it's not here.
    i've only cluster
  13. #11
    italy
    nobody?
    if i test different dump it work
    but i've only cluster
  14. #12
    italy
    this dump it's from other cluster same number and on beanch working all good.
    can someone can swap manually immo data from my original dump in this one?
  15. #13
    Dec 2010
    test org file bin
  16. The Following User Says Thank You to tigar For This Useful Post:
    fra69 (22nd July, 2022)
  17. #14
    italy
    Quote Originally Posted by tigar View Post
    test org file bin
    not work still 9999999
  18. #15
    italy
    problem not solved jet?
    any help?
