Page 3 of 3 FirstFirst 123
Results 31 to 43 of 43
  1. #31
    I don't think it would be so easy, there's a big difference between 2000 and 2005. Add to that the different platforms and protocols, you'd have a real mess.
    Maybe the better way is to use all the hardware and wiring from the Liberty in the WJ, SKIM module, peripherals and all. Just my thought, not knowing for sure. I do know that when we change VINs in PCMs, the box numbers have been the same. Have changed PCM from California to Federal, to find out the LDP/EVAP systems were different. Have not been able to reprogram a Chrysler PCM with any different calibration that it came with, only update.
    It may be possible, the only way to know is to try it, I doubt anyone could tell you it would surely work.
  2. #32
    Oct 2011
    Thanks for the fast reply
    The Liberty and GC share a lot of the same systems and protocols.
    For instance you can take the EVIC from the GC and use it in the Liberty to get fuel milage etc..
    Fortunately the 2005 Liberty still used the PCI protocol where I think that they went to CAN-BUS in 2006.
    I have access to the SKIM module and key set etc in the Liberty.
    I would like to have the GC VIN show up when the PCM is scanned however.
    Maybe use the Liberty SKIM and have a reset done on it then program in the GC VIN?
    Not 100% sure, but there should be a way.
    IIRC the SKIM communicates with the PCM via PCI bus so in theory maybe the GC SKIM would work. Hard to say without with trying it I guess.
  3. #33
    It's worth a try, only way to know for sure. Hopefully anything you change can be recovered if needed. I'll be curious how it works out.
  4. #34
    Oct 2011
    Quote Originally Posted by kevinb2u View Post
    I'll be sure to do a full backup of the PCM before starting.
    Crossing fingers LOL
  5. #35
    Quote Originally Posted by mytunes View Post
    Now I'm lost, how can you do a full backup? If there's special hardware or software, that's what I've been wanting to learn.
  6. #36
    Oct 2011
    You can read everything from the PCM using a BDM device.
    Normally the VIN # is stored is the serial EEPROM. Not sure if the PCM also stores the 4 digit SKIM code or just the SKIM module.
    I am getting a J2534 pass thru device and using the J2534 toolbox from Drew Tech you can change VIN in PCM and also reset SKIM
    I would think it's also possible to use winols to change VIN in PCM's serial EEPROM that way.
  7. #37
    The PCM stores the 'secret code' from the Skim in it so without a Skim reset you car won't start. Changing vin alone won't suffix.
    Sent from iPhone 4S
  8. #38
    Oct 2011
    Quote Originally Posted by sogaro View Post
    Thank you!
    You don't happen to have the address location in the serial eeprom do you?
    I can't remember if it was this forum or another where the posted the correct hex values for the decimal numbers.
    I'd imagine I would be able to search for it that way.
    I know the address of it in the SKIM module but that doesn't help me since I will be leaving that the same.
  9. #39
    You need Dealer tools to do it as far as i know and they are pretty very expensive
    Sent from iPhone 4S
  10. #40
    Oct 2018
    Thank you!
    Were you ever able to find the address location in the PCM?
  11. The Following User Says Thank You to sidepipe87 For This Useful Post:
    hunter123xyz (15th December, 2023)
  12. #41
    Russia, Saint-Petersburg
    Sometimes possible fix P0601 with this solution: https://carscanners.net/how-to-error-p0601-repair-jeep-gra…/
  13. #42
    alclot's Avatar
    Melee Island
    Hi mates,
    I found so intereting this post. Can anyone recomended me a tool which can modify vin and update flash on SBEC III chrysler ecm?
    Thanks in advance
  14. The Following User Says Thank You to alclot For This Useful Post:
  15. #43
    Dec 2023
    I realize that this a rather old thread, but just wanted to thank you all for your great information, Finally, I was able to get rid of the a SKIM module, by using a SNAP ON PRO III device and the Drew Toolbox J2534 software running under Windows 10, I kept my PCM, as the issue was with the SKIM module itself, so I just disconected the battery, then the SKIM module, then I did a SKIM/RESET, and VIN and SRI rewrite, and the engine started right the way. Thanks again and regards to all of you.
