Xentry XDOS (OpenShell) + XPT (Passthru) 12.2021 Update 09.2022.
For Old PCs (Windows 8.1 Ru-Eng). Image for SDD or HDD. / Cloud download
The main uniqueness of the image is in the additional assembly of XPT on top of XDOS. For those in the know, this means transferring part of the XDOS functionality to XPT.
Trucks are now available for passthru adapters (within the capabilities of your adapter!!!). It requires a little straightening with a file, i.e. add one key to the configuration.
For example, Scanmatik is starting to work with Aktros, and Python (and other adapters with support for APIs 02 and 03) can even dig into AXOR
Year/Date of Issue: 07.2022
Version: 12.2021
System requirements: CoreDuo, 2+Gb RAMM, HDD 160Gb
Windows Interface language: English + Russian or download language pack for any
Medicine: gone, but... Don't worry, this is a joke, examine the desktop carefully
Description: Xentry XDOS Passthru 12.2021 Update 09.2022. For Old PCs (Windows 8.1 Ru-Eng). Disk image.
OFFLINE-ONLINE MODE, HHTWIN, NTWDNx64 Native mode (Antiviruses do not swear).
Xentry Interface language: Multilingual as usial
After updating the drivers, you will have to reinstall NTVDMx64. You can find it on the network, uninstall it from the control panel, reinstall, and the HHTWIN functionality will be restored. HTTWIN does not work with simple J2534 shoelaces without a multiplexer due to the electromechanical limitations of these shoelaces!!!
Sometimes a message pops up - "you do not have access rights", this is due to the limitation of the "activator from the disinfector", it falls out for everyone, and not just in this assembly.
To cure it, run its keyken from the desktop as administrator, agree to install the library and close it. Everything.
]Some people think that if you put any keygen on the desktop and run it, it will solve the problem. It is necessary to have a snack exactly the one that lies there initially !!!
Then I'll build it into the mode switch, just wait for it to work for me again and find out which of the Xentry components restores.
Build Features:
Windows Embedded 8.1 x64 Industry Pro (Eng-Ru). Other languages need to be downloaded.
Why Win8.1? Like it or not, the interface of Win10/11 is still suck and slow with old hardware and the appetite for RAM is unkillable.
The system is optimized for weak computers (CoreDuo, 3GB RAM)) without loss of functionality and desecration of the integrity of the distribution.
The OS boots in 15-20 seconds on an SSD. For HDD 30-50 seconds.
The disk will be about 100GB occupied, if you don't want problems, then a 140-160GB disk as minimum requirement.
If the RAM about 3-4GB and you can configure UWF features correctly, then you can use a 120GB SSD.
On computers with Core processors (i3, i5, i7) of the 1st, 2nd and 3rd generation with 8GB of RAM, system really soars.
I recommend using an SSD because the Xentry is a very cumbersome tool itself .
Everything that needed to be disabled or suspended is done.
There is a built-in antivirus MS DEFENDER (off by default) and Firewall. You never know, you want to go online and download something.
If you have your own key for Windows, then use it, if not, then look for KMS as method.
The system was originally installed and optimized on a laptop with a CoreDuo processor, 3GB of RAM and does not contain extra driver, so after turning around you may need drivers for your computer and you can be sure that a lot of extra "from the assembler" will not rise.
Drivers can be downloaded via Windows Updates.
You can also remove drivers from Nvidia if integrated video, and/or install drivers from AMD video adapter.
The minimum recommended disk size is 120GB. Preferably an SSD because Xentry is very bulky by itself.
MBR (Legacy) bootloader. Be sure Legacy boot mode selected in bios.
The build is fully functional and completely "free" for your needs, but will ask for keys for Xentry since you have different hardware.
I do not distribute keys and keygens, do not ask, but all the software prepaired, just use any key from free access by requesting it on any thematic forum.
Since the system was prepared for the budget sector with C3, C4 and PassThru, the support for Bosch VCI MT6532 present, but not tested.
Image collected using Macrium Reflect v.7
You can download from a torrent or a FREE version from the program website https://www.macrium.com/reflectfree
It is most convenient to unpack and deploy on a computer with the patient's disk connected. But you can make a bootable USB flash drive with the same program.
1. Deploy the image to the patient's disk using one of the above mentioned methods;
1a. Write in private messages for remote installation via TeamViewer or AnyDesk (only for donors);
2. IMPORTANT! Boot target system and after installing the necessary drivers, run the Winsat FORMAL command from the command line interface with administrator rights;
2a. If the drive is not an SSD and/or the memory is less than 3 GB, then enable the paging file in the Windows settings;
3. If you want to prevent the window from being updated, then the reg-file is attached, but the antivirus will also stop updating;
4. How to activate? Write to private messages for remote activation via TeamViewer or AnyDesk (only for donors);
In addition to activation, a complete reconfiguration of the PC will be performed until it is fully ready, the C3 multiplexer will be finally configured (C3 still under construction).
Removed image transfer tails to your PC.
Optionally, blocking from changes can be enabled, each download is like the first time. But RAM memory requires at least 4 GB.
The Xentry provides the ability to activate the "long key". If you have the key, you can do it yourself.
Do not use a short key, even if the key is accepted, the functionality of XENTRY will be truncated, and interruptions in the launch of DAS are also possible.
5. The functionality for blocking the system from changes (UWF) is integrated. You just need to enable it and configure.
6. IMPORTANT! IMPORTANT!After deployment, everything is set to C4 Passthru - I don't remember. Passthru-SDConnect mode switching is always available and everything will be reconfigured.
Activation of the Xentry only through the simulator mode. Switch between SDConnect and Passthru with on-screen buttons.
In principle, a reboot is not required, but it is desirable. I recommend that Russian speakers do not change the language of the operating system, switch the language only in Xentry. Otherwise, you will have to reinstall NTVDMx64. You can find it on the network, remove it from the control panel, install and reboot, and the HHTWIN functionality will be restored. HTTWIN does not work with simple J2534 shoelaces without a multiplexer due to the electromechanical limitations of these shoelaces!!!
The image is aimed at experienced users and does not contain any instructions, manuals and other unnecessary information, this is an EXCLUSIVE WORKING TOOL.
If you need to screw WIS / ASRA and EPC, it is desirable to have an SSD disk and more than 4 GB of RAM. In principle, it will work without these requirements, but the system load will increase from seconds to 3-5 minutes.
MEGA download available for donors. Ask PM (Telegram: @Bes_Prikras).
P.S. For technical question always welcome to forum.
P.S. To activate the antivirus, make changes to the registry
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Win dows Defender]
"DisableAntiSpyware"=dword:00000000
