I need to know if its possible using op-com, to program the psg16 diesel pump in, if pump has been reset. As usually the car hasnt arrived yet need to know if its possible first.
Much thanks in advance as always
yes you can code the pump in using the code on the carpass, if it hasn't been reset first you need the code from the donor vehicle first to divorce it from the original car & then re-code it using code from customers car
givusaclue
Did this today, tried using 090281d, there is a fault in software on programming Psg16 pump. Had to go back and use 090714, that did the job beautifully, just thought id share my experience to save you guys time messing like i did, thanks for all replies and to opel1234 and qiy1gd, who helped me lots thanks again.![]()
Tel me pls how reset pump or read pincode from pump ??
or buy this:
SMOK
or this:
Opel PSG16 diesel pump by OBDII - read/change mileage, read PIN, reset ECU.
Maybe i found any good friend and help me i need 2 pin :
1.W0L0TGF7552048635
2.W0L0ZCF6838054429
Thanks for any help !!!![]()
even if the pump did not have the same reference of bosch for 1 and 2 plug
when i want to replace the pump even if the pump did not have the same reference of bosch for 1 and 2 plug
