Results 1 to 10 of 10
    obdmaster's Avatar
    Never never land
    Question op-com Vectra c Y20DTH PSG16
    I need to know if its possible using op-com, to program the psg16 diesel pump in, if pump has been reset. As usually the car hasnt arrived yet need to know if its possible first.
    Much thanks in advance as always
    Jan 2010
    UK
    yes you can code the pump in using the code on the carpass, if it hasn't been reset first you need the code from the donor vehicle first to divorce it from the original car & then re-code it using code from customers car
    givusaclue
    obdmaster's Avatar
    Never never land
    Thumbs up
    Did this today, tried using 090281d, there is a fault in software on programming Psg16 pump. Had to go back and use 090714, that did the job beautifully, just thought id share my experience to save you guys time messing like i did, thanks for all replies and to opel1234 and qiy1gd, who helped me lots thanks again.
    Basti13's Avatar
    UK
    Default PSG16
    Tel me pls how reset pump or read pincode from pump ??
    obdmaster's Avatar
    Never never land
    Thumbs up
    Quote Originally Posted by Basti13 View Post
    You read chassis no. off replacement pump/ecu using op-com then send chassis no. to very good friend.
    Very good friend sends you security code, for vehicle donor pump is off, then you go into pump/ecu using op-com , programming, reset ecu.
    obdmaster's Avatar
    Never never land
    Lightbulb
    or buy this:
    SMOK
    or this:
    Opel PSG16 diesel pump by OBDII - read/change mileage, read PIN, reset ECU.
    Basti13's Avatar
    UK
    Default PSG16
    Maybe i found any good friend and help me i need 2 pin :
    1.W0L0TGF7552048635
    2.W0L0ZCF6838054429
    Thanks for any help !!!
    Basti13's Avatar
    UK
    Default PSG16
    Any good friend help mee ??
    Nov 2009
    Morocco
    even if the pump did not have the same reference of bosch for 1 and 2 plug
    when i want to replace the pump even if the pump did not have the same reference of bosch for 1 and 2 plug
    Nov 2009
    Morocco
