Results 1 to 9 of 9
    DK Veteran VTS_Tibi's Avatar
    Nov 2009
    Default Peugeot 107 / C1 / Aygo - add second key
    Hi Guys,
    I would like to add a second key to a Peugeot 107. I have a working master key which starts the engine / opens and locks the doors.
    I obtained a used key from Ebay, had the key blade cut and managed to make the remote work so it now opens and closes the doors but I can not program the immo side to the car. Peugeot Planet always gives the followign error:
    "Error in the key learning
    The key has not been registered in the immobiliser control module"
    This is after selecting:
    Immo control unit -> Key programming -> Learning new keys -> Learning using the master key
    The already programmed (master) key had to be insterted into the car, then following the prompts the tool then asked for the new key, went through the programming and at the end when it does the verification it failed.
    Any suggestions?
    Thanks,
    Tibi
    Mar 2016
    You can't program a used key, you need a new one (not used with other car).
    Envoyé de mon Elephone P8000 en utilisant Tapatalk
    Oct 2015
    Quote Originally Posted by VTS_Tibi View Post
    Hi Guys,
    Any suggestions?
    Thanks,
    Tibi
    POST KEY DATA AND IMMO DUMP I WILL ADD IT FOR YOU
    Apr 2016
    uk
    Just done all keys lost on Peugeot107 2007.
    I took off the immobox,read eep 24c04 and programmed key with tango.if you don't have Citroen or Toyota..
    U need payable option for it.About £30 tradelocks UK for Peugeot
    Inviato dal mio HTC One utilizzando Tapatalk
    p1et's Avatar
    Oct 2013
    Easiest way to add a 2nd key is just clone transponder
    Apr 2016
    uk
    Quote Originally Posted by p1et View Post
    Where to buy these transponder?I had to buy the whole key..
    joker01's Avatar
    Jan 2018
    hello, I have to do second key for aygo 2011 chip 4d66
    ok for the clone no problem .....
    but I wanted to know if with obdstar I could add a new key from obd safely ????
    I need pincode to do it or is the key enough master ???
    thanksssss
    [SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
    MartiLer's Avatar
    Dec 2016
    can be written by hand in the immo dump.
    joker01's Avatar
    Jan 2018
    yes ... i saw ..... should have eprom 24c04.......
    but i wanted to know if anyone had done the job with obdstar from obd ...
