change injectors plugs................... it is normal in that car/engine
1st is from left side of car............not like before from gearbox side !!!
Hi, have problem with opel Vivaro 2006 2.0 dci
When reach speed around 70km engine cutsoff. And apears p2146 error Roup 1 injectors supply.
restartimg car and runs ok until 70km/hand again.
measured injector wiring ,all ok.
Injector resistance . discomected from ecu
1 --1,6 mOhm
2 -- 4,2 mOhm
3 -- 4,3 mOhm
4 -- 4,1 mOhm
Injector to mase
1 pin1 --1,92 Mohm
pin2 --2.0 mohm
2 pin1 --1,9 mohm
pin2 --2.0 mohm
3 pin1 --5.3 mohm
pin2 --5.1 mohm
4 pin1 --57 mohm
pin2 --54 mohm
I dont know how much should be
need help
now my goal is to buy xp-005
who will help?
A topic that interests me
The resistance of the injector is 160-200 kΩ. If it is different, replace the injector.
darius89 (27th July, 2022)
But my all injector much more than 200 kΩ ...
Not possible that all bad. All 4 injectors was replaced 2 month ago.
Check the injectors first. Direct check. Sorry for my bad english
darius89 (28th July, 2022)
injectors corroded, from water dripping from plastic lining under front windscreen, on rare occasions ,fault could be ECU water damaged or broken wires in harness
