Results 1 to 15 of 16
    Default IMMO OFF MEGANE I 1.4L
    HI
    I need immo off RENAULT MEGANE I 1.4L year 1996
    ECU SIEMENS S111730108C
    Where immo in ecu?
    yasser's Avatar
    Bulgaria, Varna
    Is it with 35 pin's OR 55 pin's connector?
    if it is with 35pins connecytor, so maybe there inside is Motorola HC11E9
    55 pins - MCU TMS 374.
    It is a 35 pins
    yasser's Avatar
    Bulgaria, Varna
    Ok, so open ecu, read motorola 11E9 and post dump.
    DK Veteran wizz2c's Avatar
    earth
    read hc11and edit as this word doc states very easy to do
  6. The Following User Says Thank You to wizz2c For This Useful Post:
    scoot (6th January, 2015)
    [QUOTE=wizz2c;475942]read hc11and edit as this word doc
    The car start well
    I must cut immo line?
    Solved
    earth
    [quote=SIMCAR2;476065]
    Quote Originally Posted by wizz2c View Post
    The car start well
    I must cut im*o line?
    Solved
    yes cut immo wire
    SOLVED
    I cut pin 29 and is good.....
  10. #9
    DK Veteran JIMMYQ's Avatar
    Mar 2008
    hi guys as you can see i have searched but just want to make sure im going for the right chip before removing any
  11. #10
    earth
    Quote Originally Posted by JIMMYQ View Post
    Yes thats the Correct chip.
    Dont forget to say if i helped.
  12. #11
    Mar 2008
    thanks mate cant seem to read it with upa guess ill have to try some other programmer ?
  13. #12
    unu's Avatar
    Oct 2010
    EUROPE
    can be read with any HC11 programmer very simple ... isn't secured !
  14. #13
    Mar 2008
    i read the hc11 and changed the values to ff as mentioned in the file above and then cut pin 29 the car still not starting and immo light still flashing ?
  15. #14
    Mar 2008
    anyone ?????
  16. #15
    newone's Avatar
    Oct 2016
    Hello,can someone please clear immo ?
