Results 1 to 11 of 11
    Nov 2018
    Brussels
    Default Fiat 500 USA version
    Hello mates Please does anyone knows the alarm module where is located on fiat 500 2015 I have delphy BSI on it USA version I cant read the files on it due to alarm on is blocking the CAN connection to the OBD I also tried a chinese tool to read PIn but also Can is closed and not reading any help ?
    If I Help You Please Rep + Thanks ME
    p1et's Avatar
    Oct 2013
    BSI might got change in dealership to newest version without external eeprom. But open it and see if there is 93c86.
    Nov 2018
    Brussels
    First thank you for your reply I will send you the pcb and full BSI number
    Nov 2018
    Brussels
    can be read in circuit to have the dump maybe if I do that I can add key and turn the cr and alarm goes off
    Quote Originally Posted by p1et View Post
    Nov 2018
    Brussels
    Default The BSI has no eeprom
    Hello mates again as I cheked there is no eeprom on this BSI any idea which tool can read the dump of this MCU ?
    ray-ray's Avatar
    Been trying to read these bait from the USA market for awhile. I.O terminal is the tool to use
  7. The Following User Says Thank You to ray-ray For This Useful Post:
    Bryanlocksmith (4th August, 2022)
    p1et's Avatar
    Oct 2013
    If Im not mistaken, SMOK or UPA can read it in circuit but not sure.
  9. The Following User Says Thank You to p1et For This Useful Post:
  10. #8
    Nov 2018
    Brussels
    Do you have perhaps the wiring diagram ?
    Quote Originally Posted by ray-ray View Post
  11. #9
    Jun 2013
    How did this case develop ?
  12. #10
    alex_r_2001's Avatar
    New Jersey ,, USA
    Here goes wiring diagrams in case you need. Tell me which module on can bus wiring you need location of I will post picture.
    Here go wiring diagrams from IOTERMINAL as well
    Solidarity with Ukraine
  13. The Following 2 Users Say Thank You to alex_r_2001 For This Useful Post:
    Bryanlocksmith (20th October, 2022), Weasel3 (8th September, 2022)
  14. #11
    Jun 2013
    I guess Smok is capable as well ?
    Since the ioterm can do it.
    About the same, on many modules.
    Last time several years ago.
    I got the message, if alarm active.
    Nothing can be done.
    If there is a working solution, these days.
    I would be very happy.
