Results 1 to 5 of 5
    Dec 2012
    EU
    Default Honda cbr900 key info.please
    Hi all.
    I dont do bikes but friend needs a key for his bike..
    Its honda cbr 900 1998
    Is the last 3 leters is the key code A03 ??
    If it is onstacode shows Hon39 blade..
    But when i check in 3d it should be HON70 ..
    Any info welcome.
    Thanks.
    Sent from my SM-G955F using Tapatalk
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
    ray-ray's Avatar
    A03 is your keycode
  3. The Following User Says Thank You to ray-ray For This Useful Post:
    gttuning (8th August, 2022)
    newone's Avatar
    Oct 2016
    i would check also hon40-hon41,if anything go wrong with code is easy to take it apart,remove outside plastic cap and you will see a metal pin,if you remove it cylinder comes out
  5. The Following User Says Thank You to newone For This Useful Post:
  6. #4
    Oct 2011
    Croatia
    try cut hon 39 33111
  7. The Following User Says Thank You to apavlic008 For This Useful Post:
  8. #5
    Dec 2012
    EU
    Thanks guys
