A03 is your keycode
Hi all.
I dont do bikes but friend needs a key for his bike..
Its honda cbr 900 1998
Is the last 3 leters is the key code A03 ??
If it is onstacode shows Hon39 blade..
But when i check in 3d it should be HON70 ..
Any info welcome.
Thanks.
Sent from my SM-G955F using Tapatalk
Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
A03 is your keycode
gttuning (8th August, 2022)
i would check also hon40-hon41,if anything go wrong with code is easy to take it apart,remove outside plastic cap and you will see a metal pin,if you remove it cylinder comes out
try cut hon 39 33111
Thanks guys
