Results 1 to 15 of 15
    Apr 2014
    Default VVDI2 IMMO 4 service mode now mileage flashing???
    After using vvdi2 and pogo pin to put Polo 2011 dash into service mode and making two new transponders i have the mileag flashing any ideas why?
    Is this the fix?
    VDO cluster with NEC processor and 24C64 eeprom the solution is to read the eeprom, replace with FF all values including between 0x10C0 and 0x1173, and finally rewrite the eeprom
    Apr 2014
    Has any one experienced this?
    Supas's Avatar
    Jun 2020
    Do you have the original eprom?
    Apr 2022
    Germany
    Was that job direct on the car or you have only has it been remote job (with dashboard on the bench)?
    As far as I know the super VAG has an option with pogo PIN...
    But I can’t remember that VVDI2 has also this option as well...
    Maybe I am wrong, since I have been using VVDI2 on VAG directly on the car...
    Supas's Avatar
    Jun 2020
    Quote Originally Posted by wuza View Post
    The Pogo pin boot function can be used by anyone on the bench... it's nothing more than sending controlled ground to one leg of the mic to leave it in a service mode state. After that you can use the programmer you like the most.
  6. The Following User Says Thank You to Supas For This Useful Post:
    wuza (9th August, 2022)
    Apr 2014
    yes pogo pin on bench with vvdi2 . original eeprom wrote back but still a fault code left for internal module fault. iv never had this before but iv spoke to a few other people and theyve had same issue, one even when original eeprom wrote back mileage still flashing
    Supas's Avatar
    Jun 2020
    If you have a problem with pogo, you must put it into service manually... you have to put in FF from line 0x1290 to 0x1500.
    - Connect with vvdi2
    - read inmodata (will be wrong data)
    - Write original eprom
    - Re read inmodata (real inmodata)
    That way you shouldn't have any problem with making keys and km
    Mar 2018
    UK
    Quote Originally Posted by sjc1 View Post
    I had simmilar situation - I used Xtool tool to change the mileage and after that was OK
    I think that every tool that can do mileage on this car will be ok
  10. #9
    Germany
    Mileage blinking on this type of cluster I know, if lock bit is set to unlocked. Take VCDS, go into cluster (17), adaption and search for lock bit setting. Dont know the exactly name, but you will find it. You can set unlocked to lock with vcds. But not locked to unlocked. With this bit some special adaptions are locked, like numbers of fuel sensors etc. Unlocking this I only know by eeprom dump, but in your case maybe accidently by pogo. I dont like this method, because you are not the first, who messed up dashboard by this method...
    Greets MR...
  11. The Following 3 Users Say Thank You to brobble For This Useful Post:
    lupu_sandu (26th June, 2023), p1et (9th August, 2022), sjc1 (9th August, 2022)
  12. #10
    Supas's Avatar
    Jun 2020
    Quote Originally Posted by Supas View Post
    I'm back to the same thing... do you have the original file?
    Your solution is that... save original file and if you already save inmodata when you enter with vvdi2 you can make the 2 keys that are already in the system... without entering programming.
    If you want to make two transponders with a new id it's easy too and you don't have to have problems with KM.
    At no time did you mention that you wanted to modify the km, only that when writing 2 new keys that problem arose.
    He sends me a message and I help him.
  13. #11
    Germany
    I think he doesnt have eeprom dump before pogo method. If the made keys are working, he doesnt need to do service mode. He can change mileage, read/write eeprom now with obd without service mode. But changing mileage wont solve his problem I think. He messed eeprom data by pogo method. But read eeprom now and post it could help.
    Greets MR...
  14. #12
    Apr 2014
    I wrote original eeprom back and mileage stop flashing now but still have a faut for internal fault. i want to know what this has happened so i can avoid it in the future
  15. #13
    Supas's Avatar
    Jun 2020
    In my opinion it was the Pogo that happened... although it is a practical procedure... it has its risks, the ideal is to impose mass through resistance and not directly.
    Much more we can not help without having your reading.
  16. The Following User Says Thank You to Supas For This Useful Post:
    sjc1 (10th August, 2022)
  17. #14
    Dec 2016
    UK - South East
    Hi all,
    Sorry to revive this thread but I'm facing the same issue. Basically, I've upgraded the cluster on a T5.1 from basic one to highline. I've just transfered the immo data from old dash to new dash then recalibrated mileage. Now mileage is flashing. Any ideas where to start ?
    Thanks!
  18. #15
    Germany
    Yes, start by reading this threat. :-) Post 9 should be the solution.
    Greets MR...
  19. The Following User Says Thank You to brobble For This Useful Post:
    ovidiumarin (4th July, 2023)
