Results 1 to 5 of 5
    Oct 2021
    Default Hyundai - J2534 compatible VCI PassThru -
    I've been trying to perform an ECU update using an Official software Hyundai (Europe/UK - I couldn't find any name, but I don't think it still being called GDS) with some J2534 interface with no success
    Software cant communicate properly with any of the interfaces that I am trying to use
    Bosch KTS540/570 - When the software is trying to communicate, I can hear the relays from the VCI switching, but there's no communication
    PCM Tuner/ Scanmatik - Same as before
    VVDI2 - I've never see this equipment working properly with any J2534 software, But I've tried and had no success to this car too
    Question is, does someone know about it/had success with one of this interfaces or different one? Which one?
    Thanks since now
    Aug 2022
    I'm sure the Europe/UK Hyundai J2534 software is similar to the US version. If that is the case I believe it will only do 2016ish and newer vehicles. The VCI's you are using may not have the correct protocol for that. A quick search of the Bosch and PCM tuner show only 1 or 2 standards while most newer vehicles are on 3 or 4. I have used the Snap-On pass-thru 4 on one, not a cheap one for sure but I know it works. It is essentially a Cardaq 3 rebranded. I would think the Bosch MasterTech 2 would work as well. Not sure if there is just a cable out there like a Mongoose but I'm sure there is.
    Nov 2015
    Hello, can you please send me the link to Hyundai uk where to register for the j2534 software.
    Oct 2021
    Sorry for taking long to reply, I've seen it just yesterday
    https://service.hyundai-motor.com/eu...tiles?siteCd=H
    Which VCI are you planning to use, and whereabouts are you based?
    Sep 2015
    I also trying to use few vci with j2534 but no luck , is IT posible to use Red gds vci with this software?
