Results 1 to 8 of 8
    Jun 2020
    Romania
    Question GSXR K3 1000 CHANGE KM IN EEPROM
    Hi, i have 18000+ km in bin file from my k3 1000 cc, i need help change to 34000 km. Can somebody to help me? Thank's.
    nikolakismb's Avatar
    Oct 2015
    amsterdam
    I think something is wrong with your file
  3. The Following User Says Thank You to nikolakismb For This Useful Post:
    DIAG61 (11th August, 2022)
    Sep 2016
    Hungary
    ori km:40424 ?????
  5. The Following User Says Thank You to kismurmi For This Useful Post:
  6. #4
    Jun 2020
    Romania
    i uploaded 2 more bin files ,saved with another software and interface and the eeprom was L56R, i am not sure if they are ok too, maybe in the reading process something was not ok, please let me know if posible to convert to 34000 km, thank you all
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by DIAG61 View Post
    18000km dump ........out .............65 04 9A FB..........in............4D 08 B2 F7 ..............8 instances for the km value
    ...............................out..............BC 02 43 FD..........in ...........C0 03 3F FC............... same 8 instances for the miles .......
  8. The Following User Says Thank You to PremierD For This Useful Post:
  9. #6
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    only this file (k3 1000 L56R 18000 km.zip) has original mileage you post in first post (it has 18127 kms)
    K3 1000 L56R 30571 km.zip = bad read, now it's x8 bits instead of x16
    ATC93C56(16BIT) K3 1000 18000KM.zip = this file has not 18000 kms, it has 40447 kms.
    next time put full real information, dont waste our time
  10. The Following User Says Thank You to jomberykaso For This Useful Post:
  11. #7
    Jun 2020
    Romania
    Quote Originally Posted by PremierD View Post
    i've changed the instances in the file, the electrician wrote it in eeprom and finished the job, here is the positive result in attachments 33920 km for gsxr k3.
  12. The Following User Says Thank You to DIAG61 For This Useful Post:
    PremierD (17th August, 2022)
  13. #8
    Jun 2020
    Romania
    Quote Originally Posted by jomberykaso View Post
    the first file L56R with 18127 km i knew that is good, just forget precise number of km,
    the other 2 files i did't knew that they are wrong,i received them from electrician,
    now problem is solved for 33920 km
