hi try and report
http://blog.vvdishop.com/vvdi-prog-o...quency-failed/
hello
Anyone can share information how to read this bcm with VVDI2+VVdiprog?
I have try to read 3 Audi A4 BCM2 all 0711 sw from 2014 2015 cars and can't read any
I try with adapter and with soldering wire but allways VVDIprog say set frequency failed
to me it look like not powering board
and also on adapter I only have PWR light flash
do I need to power BCM from original power connector like AVDI do or I'm doing something wrong?
regards
hi try and report
I was don it whit vvdi... it work good but you need do it careful.
Thank you
I have seen this and look for frequency and it is 40000mhz and my VVdi is set to this frequency but still same
I only have 12V light flash on my orange adapter,other two not ,VCC and PWR
regards
From 2014 Audi BCM2 have are locked MCU. VVDI prog & VVDI2 can read this module only with Xhorse VVDI BCM2 Adapter.
Audi Q5 2016
0711
8K0907064KP
Was done with VVDI2+VVDIprog+BCM2 adapter
Seem that your orange adapter is broken.
yes I think it also but I never try it till now and can't return it.
I found few reports with same issue on web so it look like it had to be something wrong
I will have to order update for AVDI and try with that
Weasel3 (21st August, 2022)
Seems Abrites have it cracked
https://abrites.com/blog/the-secrets...d-bcm2-modules
not too expensive either
Solidarity with Ukraine
AVDi do not cover all versions, I have friend who got AVDI update and could not read BCM2 form 2015 .
Best tool on market is PolDiag ,very safe and never got any problem with it . VVDI is very danger on Locked BCM2, many people reported damage BCM2 after read or not work at all. Once VVDI brake it , not way to fix it , it needs New BCM2.
try AVDI today and also failed..........
I could read Part number and sw version but I can't unlock MCU,try on two different BCM2 both sw 0711 year 2014
yes,I think only online have unlocking BCM2 option
connect all as manual but can't unlock
regards
mjoesen (21st August, 2022)
Xprog-m v6.12.......
the lesser you use your brain,
the louder you use your mouth.
