Your repaired file.
Your repaired file.
Best regards.
Dragon
budata (13th August, 2022), Crasftsman (13th August, 2022), SebaGTC (14th August, 2022)
Not work. No DTCs but light on.
SebaGTC (16th August, 2022)
Change first driver on the pcb
Have same internal problem
Can someone fix it?
Tnx
Noone?
Tnx
Check and report.
Best regards.
Dragon
Servicer told me same dtc
9B05 control unit fault
9AF6 open circuit belt tension
Check elements on pcb ...
Best regards.
Dragon
ziko (16th September, 2023)
