Originally Posted by XProfig
I will share my experience.
I transferred keys from one CAS to another successfully (remote works). And I programmed a new key also (remote works). Using AESHiteger.
In CAS3 0L15Y before Hitag2 data block:
at adres 0x068 there are 10 bytes (11th byte is crc),
at adres 0xA74 there are 10 bytes (11th byte is crc),
at adres 0xA80 there are 10 bytes (11th byte is crc),
10 bytes coresponding to 10 key slots.
After you program Hitag2 data and remote data (using your tool in AESHiteger) for empty key slot you have to do one more thing to make remote work.
For every of that three 10 bytes rows, you have to change byte corresponding to the key slot you are programming.
You have to change this byte (in every row) to byte the same as it is for working remote. In most cases, working remote are (were) in two first slots.
I'm attaching example for programing key on slot 9.
