I have a Golf 4 1.616v 2003 engine code BCB.
Earlier this year I had an issue with G188 sensor on throttle body, after month of diag, It figure the issue was in the ECU EEPROM, after changing the issue by an used one, i finally succed in the ECU to IMMO adaptations.
Now The G187 and G188 are perfectly working when I move the throttle with and.
But whenstarting, the engine can't ake more than 2500 rpm and I have a fault code with VCDS : P1545 Throttle body malfunction.
I can't perform a throttle body Adaptation as VCDS return me ERROR on the Status box of the TBA channel.
I have exactly the same issue with my old Throttle body and with a brand new one I just baught.
Can you help me please?
I can provide further info on the former ECU issues or if more info on car and default is needed.
thank you
best regards
