Continental-Siemens has injectors. This is PIEZO. I check the elements with instruments. Look at the injector corrections on the scanner. For piezo, gaps are needed, which can be made on the stand.
You have K9K 836 ....
Connect the computer, you will see the injector corrections. You could try swapping the injectors. The problem should go away for a while. 1 cylinder from the flywheel.
And about signals, there are not electromagnets, but piezo. they have an opening - 160 Volt / and time .. Get me a signal with an oscilloscope and then I'll tell you where to dig.
