CS2 is 00000000000000
can someone help me
I tried to write the flash file in the TCM via OBD and since then the key does not turn the lock
on the dashboard it says 1/0 for the key
attached are the files via OBD and on the bench with VVDI
I read through obd with AVDI orginal,the reading was when the key stopped turning the lock
CS: 1C D3 00 26 39 A6 xx
MAC: 52 0C 4D 98
PIN: 14067
Power class: 92
AE Simic 026 (17th August, 2022)
What engine and transmission do you have?
TCM Via OBD on this car . Only know way I know to read/write this TCM is with Flex bench mode, never heard anyone did OBD.
Anyway Data is lost on this car , forget about it , You only option is to find good used EVL and adopt it with ODIS.
AE Simic 026 (19th August, 2022), nenadgorgi (18th August, 2022)
OK, if the key and ezs to each other u can unlock it the key. but after unlock u have to do many procedures, first must write pin mac CS1 vin PC of original in new used ezs and after adapt key to new used ezs and after adapt to ecu and also adapt ezs to (components protection) by obd2, when done this all, read the present dump from ezs and load in tcu adapting system and adapt ezs to tcu by obd2. with me 2 times done this procedure even cs2 in ezs different. give a try...
i coded ezs.I changed pin and cs
now power class 79 in ezs and main ecu is 92
how to change power class in ezs
