Here you go password in Pm if you get any dtcs let me know
begi1 (18th August, 2022)
You can leave MAF connected ECU just doesent use it anymore but if you want you can disconnect it and remove it but you will get open circut DTC for maf but if you dont mind check engine light then just leave it if you mind it the you need to short two pins on MAF connector and delete MAF sensor implossible signal DTC that how i do it
