Results 1 to 8 of 8
    dule14786's Avatar
    Nov 2018
    Skopje Macedonia
    Default skoda yeti nec+24c32 dashboard swap problem
    a have change instrument cluster transfer immo from old to new instrument everything is good only a have dtc for fuel level sensor 2 and needle for fuel don't show correct level on tank
    and a think the donor dash is from 4x4 yeti because this car have two fuel reserve a have checked coding Whit vcds but don't find anything to change coding and remove second fuel level sensor 2 because car don't have 2 senzor any solution for this problem
    Rep & Thanks If I Helped
    upload eeprom dump old and new cluster!
  3. The Following 2 Users Say Thank You to cristo_844 For This Useful Post:
    dule14786 (23rd August, 2022)
    Oct 2014
    Netherlands
    The new cluster seems to be configured for 2 fuel sensors. This can be fixed in eeprom indeed.
  5. The Following 2 Users Say Thank You to H2Deetoo For This Useful Post:
  6. #4
    dule14786's Avatar
    Nov 2018
    Skopje Macedonia
    Quote Originally Posted by H2Deetoo View Post
    Quote Originally Posted by cristo_844 View Post
    a have upload old from dash car and new from donor dash
    May 2016
    Your file 1 sensor.
  8. The Following 3 Users Say Thank You to naprawa5 For This Useful Post:
  9. #6
    Maartinj's Avatar
    Nov 2010
    try this one
  10. The Following 3 Users Say Thank You to Maartinj For This Useful Post:
    dule14786 (6th September, 2022)
  11. #7
    dule14786's Avatar
    Nov 2018
    Skopje Macedonia
    a will test when customer return car in workshop
  12. #8
    dule14786's Avatar
    Nov 2018
    Skopje Macedonia
    Quote Originally Posted by Maartinj View Post
    try this one
    dont have time to check your file but thanks for your help
    Quote Originally Posted by naprawa5 View Post
    Your file 1 sensor.
    thanks your file is working perfectly
