Kindly Asking for long coding help with a 2013 VW Jetta for the ABS Module
VIN : WVWZZZ16ZDM050562
ABS: 1k0907379BL
ABS: 1k0907379BL
In Trinidad Tabago you need to know that cars are right hand drive. And try to go to the service and do a full autoscan.
I can suggest a trade designation for this car - 1623Q5, it will help a lot to make the correct encoding.
And if memory serves, BL blocks were placed on the US market, mainly under the indirect control of TPMS, and here we see a different trade designation, so we need to tell if there was a replacement 03 ??? And autoscan????
Ok so I don't yet have a VCDS but I hope an OBDEleven output can suffice. Note the car has some other issues that are being worked on but at the moment I'm handling the ABS issue.
OBDeleven vehicle history log
Date: 2022-08-30 04:03
VIN: WVWZZZ16ZDM050562
Car: Volkswagen Jetta
Year: 2013
Body type: Saloon
Engine: CTHD
Mileage: 97920 KM
Full scan
Control Units: 21
Fault count: 56
Control Units:
77 Telephone
System description: TELEFON
Software number: 7P6035730K
Software version: 3200
Hardware number: 7P6035730K
Hardware version: H15
Serial number: 00007663682169
ODX name: EV_UHVNA
ODX version: 002720
Faults:
U015500 - Lost Communication With Instrument Panel Cluster (IPC) Control Module
Intermittent
56 Radio
System description: Radio RCD510
Software number: 5K0035190B
Software version: 0236
Hardware number: 5K0035190B
Hardware version: 006
Serial number: VWZ1Z3P0398816
Faults:
01317 - Instrument cluster control module No signal/communication
Intermittent
03138 - Input AUX IN Open circuit
static
52 Passenger Door
System description: TUER-SG BT
Software number: 561959702
Software version: 0515
Hardware number: 3C0959792B
Hardware version: 002
Serial number: 0005905298
ODX name: EV_TSGBPQ35BRFVW46X
ODX version: A04001
Faults:
B11EC54 - Motor for front window regulator No basic setting
static
U111100 - Function limitation due to missing message
Intermittent
B11ED04 - Rear door control module Faulty
static
B11EDF2 - Rear door control module not coded
static
B11EE54 - Motor for rear window regulator No basic setting
static
4F Central Electrics 2
System description: EZE_2
Software number: 7N0907532
Software version: 1634
Hardware number: 7N0907530AH
Hardware version: H50
Serial number: 19111203290204
Faults:
No trouble codes found
44 Steering Assistance
System description: EPS_ZFLS Kl. 69
Software number: 1K0909144P
Software version: 3305
Faults:
03803 - Steering angle sensor for power-assisted steering no or incorrect basic setting/adaptation
static
Intermittent
00750 - Warning lamp Please read DTC
Intermittent
42 Driver Door
System description: TUER-SG FT
Software number: 561959701
Hardware number: 3C0959793B
Serial number: 0005889339
ODX name: EV_TSGFPQ35BRFVW46X
ODX version: A04001
Faults:
static
Intermittent
static
B122C01 - Central locking motors, rear Electrical error
Intermittent
B122E29 - Rear lock unit for central locking Implausible signal
Intermittent
2E Media Player 3
System description: SG EXT.PLAYER
Software number: 5N0035342F
Software version: 0546
Hardware number: 5N0035342F
Hardware version: H18
Serial number: 7663759918
Faults:
Intermittent
25 Immobilizer
System description: IMMO
Software number: 5K0953234
Software version: 0705
Hardware number: 5K0953234
Hardware version: H07
ODX name: EV_Immo_UDS_VDD_RM09
ODX version: A03709
Faults:
19 Gateway
System description: J533 Gateway
Software number: 7N0907530AH
Faults:
00381 - Instrument cluster data bus No signal/communication
Intermittent
17 Dashboard
System description: KOMBI
Software number: 5C6920872
Hardware number: 5C6920872
Serial number: 00000000000000
ODX name: EV_Kombi_UDS_VDD_RM09
ODX version: A04716
Faults:
B103E1B - Fuel gauge sensor 1 Resistance too high
static
B104133 - Oil Level Thermal Sensor Signal too long low
Intermittent
B200049 - Ctrl. module faulty
static
16 Steering Column
System description: Lenks.Modul
Software number: 1K5953507T
Software version: 0080
Hardware number: 5K0953549B
Hardware version: 008
Serial number: 90440LJE000F9
ODX name: EV_SMLSNGKUDS
ODX version: A05001
Faults:
B114913 - Windshield wiper intermittent mode switch Open circuit
static
U108E00 - Control unit in steering wheel No Communication
static
15 Airbag
System description: AirbagVW10
Software number: 5C0959655C
Software version: 0613
Hardware number: 5C0959655C
Hardware version: 013
Serial number: 003G6M07N43+
ODX name: EV_AirbaVW10SMEVW360
ODX version: A01014
Faults:
B10001B - Driver airbag igniter Resistance too high
static
Intermittent
U016700 - Lost Communication With Vehicle Immobilizer Control Module
Intermittent
10 Parking Assistance
System description: PARKHILFE 8K
Software number: 5C6919475
Software version: 0005
Hardware number: 7E0919475A
Hardware version: H10
Serial number: 84091234000697
ODX name: EV_EPHVA18VW3610000
ODX version: 001003
Faults:
U112100 - Databus missing message
Intermittent
09 Central Electrics
System description: BCM PQ35 M
Software number: 5K0937086M
Software version: 0068
Hardware number: 5K0937086M
Hardware version: 021
Faults:
00059 - Terminal 30 for interior illumination Short circuit to ground
static
00979 - Right low beam headlamp bulb Open circuit/short circuit to B+
static
00988 - Right brake light bulb Open circuit/short circuit to B+
static
Intermittent
01499 - Right high beam headlamp bulb Open circuit/short circuit to B+
static
01500 - Right fog light bulb Open circuit/short circuit to B+
static
01503 - Bulb for high-mount brake light Open circuit/short circuit to B+
static
01518 - Left back-up light bulb Open circuit/short circuit to B+
Intermittent
02394 - Bulb for left front parking light Open circuit/short circuit to B+
static
08 Air Conditioning
System description: Climatronic
Software number: 3AA907044AF
Software version: 0303
Hardware number: 3AA907044AF
Hardware version: H03
ODX name: EV_Climatronic
ODX version: A01010
Faults:
Intermittent
B10AE14 - High pressure sensor Open circuit/short circuit to ground
static
03 Brakes
System description: ESP MK60EC1
Software number: 1K0907379BL
Software version: 0152
Hardware number: 1K0907379BL
Hardware version: H31
Faults:
01130 - ABS operation Implausible signal
Intermittent
01276 - ABS hydraulic pump Faulty
Intermittent
01042 - Control module not coded
static
00150 - Plausibility brake booster system
static
01435 - Brake pressure sensor 1 no or incorrect basic setting/adaptation
static
00778 - Steering angle sensor no or incorrect basic setting/adaptation
static
01423 - Lateral acceleration sensor no or incorrect basic setting/adaptation
static
16352 - Control module Faulty
static
02 Transmission
System description: GSG DSG AG7 431
Software number: 0AM300058P
Software version: 4542
Hardware number: 0AM927769D
Hardware version: D20
Serial number: CU501803015296
Faults:
P1862 - Databus drivetrain missing message from instrument cluster
Intermittent
01 Engine
System description: 1.4l R4 TSI
Software number: 03C906026BG
Software version: 3743
Hardware number: 03C907309Q
Hardware version: H02
ODX name: EV_ECM14TSI01103C906026BG
ODX version: 001002
Faults:
U102500 - A/C control module Read out DTC
static
P164C00 - Reduced oil pressure switch Implausible signal
Intermittent
P019600 - Engine Oil Temperature Sensor Circuit range/performance
Intermittent
P212700 - Throttle/Pedal Pos. Sens./Switch E Circuit Low Input
static
Intermittent
P10A000 - Actuation regulating flap for intake air Electrical error
static
P226100 - Turbo Boost Pressure Not Detected Mechanical
static
P055500 - Brake Booster Pressure Sensor Circuit
static
P010800 - Manifold Abs.Pressure or Bar.Pressure High Input
Intermittent
Mileage: 97920 km
Date: 2022-08-26 12:12
Long coding
Control unit: 56 Radio
Old value:
01000410040006
New value:
05000410040006
Mileage: 97920 km
Long coding
Control unit: 2E Media Player 3
Old value:
010000
New value:
010100
Mileage: 97920 km
Date: 2022-08-26 12:10
Long coding
Control unit: 17 Dashboard
Old value:
171A00
New value:
171B00
Mileage: 97470 km
Date: 2022-08-24 13:51
Full scan
Control Units: 21
Fault count: 36
Control Units:
Faults:
static
00446 - Function limitation due to insufficient voltage Lower limit not reached
Intermittent
00447 - Function limitation due to excessive voltage Upper limit exceeded
Intermittent
static
static
01134 - Alarm horn Lower limit not reached
Intermittent
Intermittent
01496 - Left fog light bulb Open circuit/short circuit to B+
Intermittent
static
static
static
Intermittent
static
02395 - Bulb for right front parking light Open circuit/short circuit to B+
Intermittent
08 Air Conditioning
ODX version: A01010
Faults:
Intermittent
static
03 Brakes
Faults:
03306 - Coding invalid
Intermittent
Intermittent
static
static
static
static
static
static
02 Transmission
Faults:
Intermittent
01 Engine
ODX version: 001002
Faults:
static
P056200 - System Voltage Low Voltage
Intermittent
static
static
static
Intermittent
P157000 - Engine Control Module (ECM) disabled
Intermittent
static
static
static
P003300 - Turbo Charger Bypass Valve Control Circuit
Intermittent
Mileage: 97470 km
Date: 2022-08-24 13:47
Long coding
Control unit: 09 Central Electrics
Old value:
08000A3A802DE1C040080080000001E403000088508089605C 8000000040
New value:
08000A3A802DE1C0408800801000816403000088508089605C 8000000040
Mileage: 97470 km
Date: 2022-08-24 13:46
Long coding
Control unit: 08 Air Conditioning
Old value:
0000004002
New value:
0010004002
Mileage: 97470 km
Long coding
Control unit: 03 Brakes
Old value:
0000000000000000000000000000000000000000
New value:
Mileage: 97470 km
Date: 2022-08-24 13:41
Full scan
Control Units: 21
Fault count: 64
Control Units:
77 Telephone
ODX name: EV_UHVNA
ODX version: 002720
Faults:
U140000 - Function restriction due to insufficient voltage
Intermittent
56 Radio
Faults:
Intermittent
00870 - Left front bass speaker Open circuit
Intermittent
00876 - Left rear treble speaker Open circuit
static
00877 - Right rear treble speaker Open circuit
static
00856 - Antenna, on radio Open circuit
static
03272 - External audio source connection No signal/communication
Intermittent
52 Passenger Door
ODX version: A04001
Faults:
static
B11F814 - Heated outside rear-view mirror Open circuit/short circuit to ground
Intermittent
B122B01 - Central locking motors Electrical error
Intermittent
B11FD01 - Turn signal in exterior rear-view mirror Electrical error
Intermittent
Intermittent
Intermittent
Faults:
Faults:
03803 - Steering angle sensor for power-assisted steering Implausible signal
Intermittent
01316 - Brake control module Please read DTC
Intermittent
01299 - Diagnostic interface for data bus No signal/communication
Intermittent
42 Driver Door
ODX version: A04001
Faults:
Intermittent
Intermittent
B122D29 - Lock unit for central locking Implausible signal
Intermittent
2E Media Player 3
Faults:
00457 - Vehicle Electrical System Control Module No signal/communication
Intermittent
25 Immobilizer
ODX version: A03709
Faults:
19 Gateway
Faults:
01304 - Radio No signal/communication
Intermittent
Intermittent
17 Dashboard
ODX version: A04716
Faults:
U005600 - Vehicle Communication Bus D Performance
Intermittent
16 Steering Column
ODX version: A05001
Faults:
Intermittent
15 Airbag
ODX version: A01014
Faults:
static
B10021B - Passenger airbag igniter Resistance too high
static
B10061B - Driver side seat belt tension igniter Resistance too high
static
B10071B - Front passenger side seat belt tension igniter Resistance too high
static
Intermittent
U014600 - Lost Communication With Serial Data Gateway Module "A"
Intermittent
Intermittent
ODX version: 001003
Faults:
B10FC13 - Front park assist sensors Open circuit
Intermittent
Intermittent
Faults:
00526 - Brake light switch Implausible signal
Intermittent
01134 - Alarm horn No signal/communication
static
01299 - Diagnostic interface for data bus no or incorrect basic setting/adaptation
Intermittent
01495 - Left high beam headlamp bulb Open circuit/short circuit to B+
Intermittent
static
03156 - Anti-theft alarm system sensor No signal/communication
Intermittent
08 Air Conditioning
ODX version: A01010
Faults:
B108315 - Left footwell vent temperature sensor Open circuit/short circuit to B+
Intermittent
B108415 - Right footwell vent temperature sensor Open circuit/short circuit to B+
Intermittent
Intermittent
Intermittent
Intermittent
Intermittent
B108A15 - Evaporator temperature sensor Open circuit/short circuit to B+
Intermittent
Intermittent
B10BE96 - Fresh air blower, front Internal malfunction
Intermittent
03 Brakes
Faults:
00668 - Vehicle voltage terminal 30 Lower limit not reached
Intermittent
03840 - Right front speed sensor, incorrect signal
Intermittent
00285 - Right front ABS wheel speed sensor Electrical error in circuit
Intermittent
static
static
02 Transmission
Faults:
P1887 - Vehicle Speed Signal wheel speed from brake control module Implausible signal
Intermittent
P1867 - Databus drivetrain missing message of steering columns electron.
Intermittent
P1880 - Data bus missing message from Diagnostic Interface CM
Intermittent
Intermittent
Intermittent
01 Engine
ODX version: 001002
Faults:
U101700 - ABS brake control module Read out DTC
Intermittent
Intermittent
P068A00 - ECM/PCM Power Relay De-Energized Performance - Too Early
Intermittent
static
P030400 - Cyl.4 Misfire Detected
static
P030000 - Random/Multiple Cylinder Misfire Detected
static
Mileage: 247380 km
Date: 2022-08-12 10:33
Long coding
Old value:
171B00
New value:
171A00
Mileage: 247380 km
Date: 2022-08-12 10:30
Backup
Control unit: 25 Immobilizer
ODX version: A03709
Backup name:
Long coding:
000000
Advanced identification:
Workshop code and date of last update programming of SW module:
Year:
Month:
Day:
Device number:
Importer number:
Dealership number:
Programming status:
Correct result
Year:
Month:
Day:
Device number:
Importer number:
Dealership number:
Programming status:
Correct result
Year:
Month:
Day:
Device number:
Importer number:
Dealership number:
Programming status:
Correct result
Date of last coding:
Year:
22
Month:
6
Day:
25
FAZIT-identification:
Manufacture location index:
ZYS-000
Day of manufacture:
09.12.12
Manufacturer- test stand number:
4131
Running manufacturer number:
2661
Identification of standard software:
Standard software module:
BAP
Primary version number:
Secondary version number:
4
Revision number:
OSEK - operating system
3
14
Revision number:
High Speed - Network management
12
Revision number:
VW/Audi part number:
5K0953234
SoftwareVersion:
0705
Serial number:
Vehicle Identification Number (VIN):
WVWZZZ16ZDM050562
Hardware part number:
5K0953234
System description:
IMMO
Adaptation workshop code:
Device number:
22
Importer number:
Dealership number:
Date of last adaptation:
Year:
Month:
Day:
ASAM/ODX file identification:
Parameter set part number:
Parameter set version:
ASAM/ODX file version:
A03709
HardwareVersion:
H07
Vehicle equipment code:
2D2D2D2D2D2D2D2D
Coding workshop code:
Device number:
12313
Importer number:
770
Dealership number:
System abbreviation:
J334
Versions of software module:
0030
0006
0006
0000
0000
0000
0000
0000
0000
0000
Installed condition documentation:
Hardware subassembly:
Hardware sorting key:
Software subassembly:
Software sorting key:
Variant of software type:
Programmability status:
Programmability:
programmable
Program consistency:
Program present
Mileage: 97930 km
Date: 2022-07-28 15:27
Diagnostic session
Value: VW - diagnostic mode
Mileage: 97930 km
Date: 2022-07-28 15:25
Diagnostic session
Value: OBD-diagnostic mode
Mileage: 97930 km
Basic settings
Name: Resetting of all adaptation values
Status:
Mileage: 97930 km
Date: 2022-07-28 15:17
Backup
ODX version: A04716
Backup name: shots(old)
Long coding:
171B00
Adaptations:
Activating and deactivating all development messages:
Development messages:
not active
Service-key settings:
p_write_delay_time:
40 s
p_write_delay_speed:
20 km/h
p_write_distance:
20 km
p_forcewrite_qual_time:
10 s
p_main_switch_keyless:
On
p_main_switch_basis:
On
Display depiction:
Display depiction:
Not available
Service_Key_Clear_All_Counters:
clear_all_counter:
Yes
Twindrive:
Function status:
not active
velocity_detection:
Speed source:
Distance impulses
Distance impulses:
4
indicator_celebration:
Zelebrieren:
not active
Distance:
Distance:
97930 km
WIV: Coding of Service Interval Extension (SIE):
Status ESI or SID:
ESI or SID on
Selection of ESI or SID:
Extended Service Intervals (ESI)
Oil level:
Oil level evaluation
oil pressure:
Dynamic oil pressure
Remote clock receiver:
Without remote clock receiver
Oil quality:
Poor oil quality
TOG:
Oil level thermal sensor connected to instrument cluster
WIV: Resetting ESI:
Reset
Language version:
US English
Display correction of consumptions and operating range:
100 %
Seat belt warning:
Gurtwarnung:
Version 4
Hour:
0 h
Minute:
1 min
Display correction of fuel gauge:
Anzeigekorrektur Kraftstoffvorratsanzeige:
0.0
Speed threshold of dynamic oil pressure warning:
Offsetwert:
kein Offset
SIE: distance driven from inspection:
3800 km
SIE: time from inspection:
97 d
SIE: oil quality:
Poor oil quality
SIE: soot entry:
m-Aequivalent0..819100 in 100km:
0 km
SIE: thermal load:
6300 km
Additional coding:
Speed source:
via CAN
Coolant temperature source:
via CAN
Locking bit:
locked
Tank characteristic curve:
Number of fuel level sensors:
Units adjusted:
Temperature:
°C
Distance:
Kilometers
Speed:
Kilometers per hour
Pressure:
Bar
Volume:
Liter
Time:
24h
Date:
dd_mm_yy
Consumption:
Liters per 100 km
SIA: maximum value of distance to service:
15000 km
SIA: maximum value of time to service:
372 d
Indicator light for start-stop operation:
active
Automatic door locking:
Yes
Pause recommendation:
Yes
Emergency telephone number:
Status:
not active
Preselection:
000000000000
Telephone number:
Volume to be replenished:
No
Program memory status:
Error in flash memory:
No
Flash memory faulty:
No
Communication error:
No
Flash memory not programmable:
No
Number of programming attempts:
Number of successful programming attempts:
Maximum number of possible update programming:
Bootloader:
1000
Application:
1000
Data record:
1000
Year:
Month:
Day:
Device number:
Importer number:
Dealership number:
Programming status:
00
Year:
Month:
Day:
Device number:
Importer number:
Dealership number:
Programming status:
00
Year:
Month:
Day:
Device number:
Importer number:
Dealership number:
Programming status:
00
Year:
Month:
Day:
Device number:
Importer number:
Dealership number:
Programming status:
00
Year:
Month:
Day:
Device number:
Importer number:
Dealership number:
Programming status:
00
Year:
Month:
Day:
Device number:
Importer number:
Dealership number:
Programming status:
00
Year:
Month:
Day:
Device number:
Importer number:
Dealership number:
Programming status:
00
Year:
Month:
Day:
Device number:
Importer number:
Dealership number:
Programming status:
00
Year:
Month:
Day:
Device number:
Importer number:
Dealership number:
Programming status:
00
Year:
Month:
Day:
Device number:
Importer number:
Dealership number:
Programming status:
00
Subassembly and series number:
ECUSupplierNumber:
2661
Year:
Month:
Day:
ZYS-000
Day of manufacture:
09.12.12
4131
2661
Manufacturer's test stand number:
ECUProductionTestSystemNumber:
4131
VWSupplierNumber:
ZYS
BAP
4
Revision number:
3
14
Revision number:
12
Revision number:
5C6920872
SoftwareVersion:
0705
Date of manufacture:
Year:
12
Month:
12
Day:
9
Serial number:
00000000000000
WVWZZZ16ZDM050562
5C6920872
System description:
KOMBI
Device number:
83205
Importer number:
771
Dealership number:
99841
Year:
Month:
Day:
A04716
HardwareVersion:
H07
Device number:
22
Importer number:
Dealership number:
J285
0030
0006
0006
0000
0000
0000
0000
0000
0000
0000
Programmability:
programmable
Program present
Consistency of EEPROM-data:
Data consistency:
valid EEPROM data
Error during last data record download:
no error
Data record modification:
Data record not changed
Parameterizability:
Parameterizable
Mileage: 97930 km
Date: 2022-07-28 15:08
Backup
Control unit: 01 Engine
ODX version: 001002
Backup name: shots
Long coding:
00250012002400000000
Adaptations:
Activation of interior auxil. heating:
active
Vehicle history data:
nAaDkFlPfNpPmCgNpHjOmFoNmKhHfGkBnInGkGgOhFlOfPiAjK jNlNmAoPjDgPkNlDlGmHeGgHoEgOkMaEmDiHpNeNfOmNcOhElG cObGnGpBjBjJgLbJdNiKePaNbIbAkIdIhKhImMmMdMcAaBkNjF fDfCkEgDaFdBmDnPjHnEdLbNdCmNaChJpBbKdNfPiDjAePlEpK dLcPfPhBaClGnMdMjBcNmCgBjAcGhImNeJjDmJkAiEjGbKnAiM fGnEaGaBaB
Bootloader:
Application:
Application 2:
Application 3:
Data record:
Bootloader:
Application:
Application 2:
Application 3:
Data record:
Bootloader:
100
Application:
100
Application 2:
100
Application 3:
100
Data record:
100
Coding length:
10
Year:
Month:
Day:
Device number:
Importer number:
Dealership number:
Programming status:
Correct result
Year:
Month:
Day:
Device number:
Importer number:
Dealership number:
Programming status:
Correct result
Year:
Month:
Day:
Device number:
Importer number:
Dealership number:
Programming status:
Correct result
Year:
Month:
Day:
Device number:
Importer number:
Dealership number:
Programming status:
Correct result
Year:
Month:
Day:
Device number:
Importer number:
Dealership number:
Programming status:
Correct result
RB8-658
Day of manufacture:
31.08.12
1263
0802
Manufacturer modification status:
Control module family:
L
Decoration variant:
M
Construction version:
H02
Manufacture version:
Diagnostic mode:
03C906026BG
SoftwareVersion:
3743
WVWZZZ16ZDM050562
03C907309Q
System description:
1.4l R4 TSI
001002
HardwareVersion:
H02
Device number:
22
Importer number:
Dealership number:
J623
Bootloader:
0356
Engine code:
CTHD
Programmability:
programmable
Program present
Serial number:
00000000000000
Mileage: 97930 km
Date: 2022-07-28 15:04
Oh yes correct Trinidad and Tobago is RHD. Also correct trade designation. There is the possibility that the ABS module may have been changed in the past but I don't have access to all of that history on the vehicle previous owner passed away.
It becomes a little clear. Do you have viber or telegram? If not, put it, I'll give you a phone number, we'll contact you directly, I'll try to write. Well, there should be a google translator. And learn Слава Украине! this will help us.
Yes I have telegram
