Page 1 of 3 123 LastLast
Results 1 to 15 of 34
    UA
    Default Honda SRS with TMS320
    There is a question for the knowledgeable people.
    There SRS Honda OBD Reset Tool and SRS unit 77960-S1A-G94-M1
    How to connect the Reset Tool to SRS unit as in shown in this picture?
    Ashraf6119's Avatar
    UK
    I personally have never used it before although i have this tool but never required to use it.
    But, as per the instruction you have to plug it in to OBD2 plug and put the Ignition to ON position and in 3 to 5 Sec it should reset it self than put Ignition to OFF position and unplug the tool.
    Anyway for more info you can read on this web site.
    welcome to SZH Technology Co.,Ltd.
    Hope This Helps
    All The Best
    Ash
    ledojo's Avatar
    Los Angeles, California, USA
    Quote Originally Posted by DarkDiver View Post
    Hi, I saw this picture, also. I would like to put something together to do the same... Did you have any luck finding the schematics?
    picture shows airbag ecu being reset on the bench not thru obd any body used it like that?
    UA
    I worked a week with this unit and the machine - Accord of 2001.
    Nothing sensible not work, exchange of data on k-line goes, but the unit does not reset.
    In the SRS reseter is CAN bus used, can be another SRS unit will work there...
    koziolek's Avatar
    Under the car
    so is it wort to buy or not?
    does someone have any success with it ?
    let me know please
    ledojo's Avatar
    Quote Originally Posted by koziolek View Post
    let me know please
    I used it a few times... once, did it work... the other times, there were other problems, but once those others problems are fixed, I imagine it will work on them, also. The two customers never called me back, so I assume my diagnostics was good and the crash data cleared.
    THIS IS DK >>>>>NOT EBAY MATE
    koziolek's Avatar
    Under the car
    how much You asking for that?
    koziolek's Avatar
    Under the car
    so whats the range of Years and models this tool support?
    koziolek's Avatar
    Under the car
    so no one know witch models and year it covers
    Oct 2010
    Bro, just do a simple quick search on goog or even on DK, you got the www infront of you just using it is sometime quicker
    koziolek's Avatar
    Under the car
    I was hopping someone has experirnce working with that
  13. #13
    it will cover civic 2001-05
    Element up to 08
    acura mdx 01-03
    i just got one from my friend ,havnot tested yet.but if every thing was repaired above menstioned models after crash,honda HDS will reset the srs light,i just did two yesterday.one was acura intergra and 01 civic.
  14. #14
    koziolek's Avatar
    Under the car
    How about Accord?
  15. #15
    koziolek's Avatar
    Under the car
    no info about Accord?
