Today open and remove cilindar lock from bmw bike bagage box with bw9 key. I have wafers number but condor xc mini want cut this key. Are there some trick or this machine cant do it?
Machine version 6.5.8
6841707059 576F526B 57416E5453 596F55 526F6B69424152
This cilinderlock isn’t full wafers.
you need to decode the fuel lock or ignition switch for full code
When I help you
PUSH on +THANKS and REP or
rokibar (8th September, 2022)
Here nothing. Simpply machine want start cut.
Waiting hxorse enginer.
Have you update the machine?
Whats the code that you have try?
i want to check it on my machine
dolphin
When I help you
This is
rokibar (9th September, 2022)
Fail is put key. For me looking problem is in high key position. Tried put plastick part under key which i do when cut keys foe renault cards but same. Xhorse enginer still no answering at my request.
Strange but this morning working with plastic part under blade. Tried this way wasn't cut. Haven't coment. Some magic.
alclot (10th September, 2022)
Hi.
Today I needed to cut this BW9 BMW motorcycle key on Xhorse Dolphin. Machine was calibrated fine but for some reason, it barely cut this blade type, I mean I needed to set +0.3mm depth to cut it like it should. Is this some bug or what?
Is it just this key or are you having problems with BW9TE or other keys
error 35 is a calibration issue the probe it to low
below the cutter height
http://blog.xhorsevvdi.com/how-to-so...code-35-and-6/
Other keys its cutting fine so far, only this was problematyczne. There was bo any error sign
