Results 1 to 3 of 3
    Jun 2013
    Default Crafter SAM module
    Hello.
    Have vw crafter 2011. Problem with interior light. There is a short in wires. Now is reapired but in SAM ecu have 090b5 dtc.
    FNrSgDefekt_ShortCircCount. Any info how can i reset this counter?
    Or only possible flash mcu inside sam?
    It may also be damaged hardware in sam - high side switch or similar- if you post good photo of pcb maybe we can see something
    Jun 2013
    Hardware i check and 100% there is no hardware problem. Component was tested and when i put 5v on pin on mcu light work. So ecu fault or software block.
