hi i have this mdf2 i try to read fis 24c32 but no read good i ahve this picture is my radio i put scl and sda in corret pin , what pin of the eprom i p ut in other point???
Hi.
You also need to connect the common wire of the radio and the common wire of the programmer between
yourself. These are the dots GND.
budata (20th September, 2022), Decode Ghost (20th September, 2022), irfa (20th September, 2022)
i can read now , tahnk you , code please
Bad read, try again!
I'm glad i was help you,don't forget the reputation and thank you !!!
2194 say carprog is but no works can i put another file in fix with another pin???
Decode Ghost (20th September, 2022), shooting (20th September, 2022)
im sorry for you read is good i compared whith another read of the another nav here whtih the same number here the another file whith 1881 pin read.jpg
you can compared whit another files and check
Look at lines 20, 40 and 60. There is same data in all 3 lines. There is code. In your file this is not the case.
1886 is your code,
please do not spam in forum, thxy
mdf2 pin please (digital-kaos.co.uk)
++++ GOOD WORK ? +++++
FIAT EMEA 7inch, Ford Sanyo, DELPHI Chrysler Jeep Dodge, DELPHI Volvo GMC Renault, Ford FIC, Fiat Turkey, Ford V Series Calc, Fiat Continental VP1 VP2 Calc, Opel Delco CDR500 & CDR2005 Calc, Mercedes Alpine Calc, Jaguar Alpine Calc, Fiat Daiichi Calc, Delphi Famar Fueguina Calc, Renault Calc, Dacia Calc, Grundig oldtimer Calc, Chrysler Jeep Dodge Panasonic Harman Becker Alpine Continental Calc, Blaupunkt Calc, Philips oldtimer Calc, Audi Aisin RNS-E Calc ....
Decode Ghost (20th September, 2022), murat332 (20th September, 2022), shooting (20th September, 2022), Zann (20th September, 2022)
No bad read, no spam , the firs post is for read the second for code. Need code off eprom please
need this please MFD2 DVD CODE OFF VWZ1Z7 RADIO NAVIGATION BLAUPUNKT - YouTube
Decode Ghost (20th September, 2022), Mankyro (20th September, 2022), Zann (20th September, 2022)
Jijijijkij, experience for read 24c32????, i can write 8.000 files and write again whith any errors , you have experience in this???
Only need to buy a martech for repair the idiots work
alonedark (20th September, 2022)
