    Sep 2014
    Somewhere
    Default Daihatsu Terios 1998 Immo Problem
    Hi to all!
    I have problem with an Daihatsu terios from 1998. The car starts and stops after 3 seconds. The DTC is about immo sync. The car has been standing for about a mounth without battery.
    I`ve attached pictures from zedbull key read and dumps from ecu and immo box. I think they must be syncronized. Any advice wi`ll be useful.
    Thanks!
    myma7up's Avatar
    Feb 2012
    Egypt
    did you tried to make jumper pin 4 and pin 13
    Sep 2014
    Somewhere
    Quote Originally Posted by myma7up View Post
    Yes! The car starts and stop immediately! The dumps are good or damaged?
    myma7up's Avatar
    Feb 2012
    Egypt
    where is the security lamp located
    immokill's Avatar
    Jun 2009
    UNIVERSE
    1c 47 is sync code and that is O K . I think that key is problem.
    Here to HELP!
  6. The Following User Says Thank You to immokill For This Useful Post:
    Jashmine1983 (2nd October, 2022)
    Ninjor s's Avatar
    Aug 2020
    Bcm2
    Quote Originally Posted by Jashmine1983 View Post
    Hi to all!
    Thanks!
    start your car
    the lesser you use your brain,
    the louder you use your mouth.
