Results 1 to 5 of 5
Hybrid View
    Mar 2019
    Italy
    Default GOLF 6 edc17c46 change only flash
    Hi everyone, i have a golf 6 2.0 tdi 140 cv with ecu edc17c46, the ecu was updated to the latest 9978 software for the second dieselgate recall. Unfortunately, as has happened to everyone, the car does not behave in the same way as before, I found the flash file of an ECU identical to mine which I believe has the original firmware not updated. I upload the two files including my original eeprom. Would it be possible to put only the flash file in mine leaving the original eeprom, or would I have problems? Thanks
    (My Original Ecu)
    ECU: EDC17C46
    Bosch SW.: 10375615561037501992
    Part Nr.: 03L906018 9978
    AsamOdx: EVECM20TDI01103L906018
    (Ecu with sw before dieselgate)
    ECU: EDC17C46
    Bosch SW.: 10375054411037501992
    Part Nr.: 03L906018 6025
    Hi !!!
    If you want to try here some files
    mprog's Avatar
    Feb 2017
    Europe
    Better use ODIS-E or VCP and downgrade ecu with FRF file. 10 minutes and job done
    BR
    File Service - contact PM
    "Naród wspaniały, tylko ludzie ku*wy" - Józef Piłsudski
    alonedark's Avatar
    Feb 2017
    Why , can you do stag1 no problem
    Mar 2019
    Italy
    Honestly, I would have preferred to go back to the original map because I was very happy with it. Unfortunately I didn't have software to copy the old map to the new file or even vcds so I thought of this solution.
