can you tell me the mileage if it is 16000 then your code is 23187 if it is 59731 then its crypto dash and you need to post dump from ecu to get login code.
I have no ecu for this Dash. My frend damage 24c08 from original Dash. In original dash speed and RPM dont work. He wanted soldered the 24c08 to new dash and he damaged the eprom.
Don,t fully understand what you need have you damaged the 24c08 chip, do you have the original file,i don,t think it is possible to get the login code from crypto dash unless you have proper tool
hello
u ll work hard if u change the dash data because the insturment no should be the same in the ecu
then u ll need to match the insturment with ecu and ur working in A4 2004 it need special care the best way is to find 1 unit (the dash + ecu ) then reload file and they can help u for the pin
our try to find some one how can give u neww data for both (dash+ecu) but u ll work hard
I don't think you'll be able to repair your old dash. Even with exactly the same file your dash will show Error.
The only chance is to put in new MCU and eeprom from different dash as crypto algorythms are embedded in ROM of MCU.
I personally tried few times to swap eeprom between same revisions of dashes and it never worked.
I can repair it. Even if eeprom is fully erased but I need the dash on my table.
No, I'm from Germany. As the other guys already told you it will not help to write other dump. It is crypted with mcu id.
Contact me if you want to have it repaired.
hi, try 5541 from the dump.
hmmm I can see 0000
God does not play dice with the universe . (Einstein)
if anything can go wrong it will . (Morphy laws)
try with this dump this dump is from brand new dash same like yours inside this dump is no pin code you must make adaptation to load data from engine ecu but to make this procedure you must now pin code from engine ecu inside to 24c04 there are is pin code with 4 digit you must convert to 7 digit pin code and then make adaptation all lost data will be back to the dash
5541 and 00000 does`t work. With virgin dump dash shows def error.
