U need a tool like this to repair your dump, the tool can decrypt dump and show U login code (crypted also)
This dash i also crypto. Someone put the millage in bed address, the eprom was soldered before. That I was thought that is not crypto dash. Pin 2604 isn`t right. My friend have called me today . On this dash with ECU immo off speed and rpm works properly. Display shows SAFE because the immo is not matched.
On this dash with ECU immo off also the speed don`t work. Client have bought broken dash.
I have got telephone number for people near me who can read this Bosch 8E0920900K dash. But first client must accept because this dash have got red display on middle, old dash was colored.
I will write what I have done. Thanks for help.
recomend you to buy vagdasch.that tool suck the code via obd from dasch or engine ecu
I got pins for both dashes. But when i maching the vehicle data in 50 chanel i got message that system is not ok.
check keystatus in measurement block. sometimes it also helps to set the dash to newmode 04 but you can do this only via obd with dejavue, dashcan, k+can.
I check today key status in measurement block. Thanks
I need PIN code for Audi S4 RB4 BOSCH 2003. Someone help me??
I need same program for read pin from board
I need PIN code for Audi RB4 BOSCH 2003. Someone help me??
RB4 D38
