Results 1 to 11 of 11
    electromech's Avatar
    Dec 2009
    Behind a large rock
    Default P38 Range Rover Mileage correction
    Hello any one here ever changed mileage on a Range Rover 1999 4.6 if so please give a brief explanation if possible. Thanks in advanced
    Fcuk up now............... ask questions later
    yasser's Avatar
    Nov 2009
    Bulgaria, Varna
    1. Remove dash from car.
    2.Open dash and remove all internal connectors and pcb from dash.
    3.You will see one BIG eeprom 28C16 i think it was NEC or something like that.
    4.Desolder eeprom and solder eeprom socket on it's place.
    5.Read eeprom and you will see that milleage is verry simple to change. It is not coded or secured.
    6.After changing eeprom information DO NOT PUT back in dash.
    7.Assemble dash and put in car.
    8.Give car in ignition and wait about 20 seconds then swich ignition OFF.
    9.Remove dash from car and then put chip inside.
    10.Put dash in car and then give ignition ON and new milleage must be on display.
    Regards.
    Dec 2009
    Behind a large rock
    Quote Originally Posted by yasser View Post
    Regards.
    Thanks but the mileage in the becm will update the cluster to original anyway around that or is the fix to leave the eeprom out of cluster as explained to fool becm then refit eeprom and both milages should be the same? SORRY HATE TO BE THICK BUT ME AND THE BECM ARENT GOOD FRIENDS
    dashradio's Avatar
    Nov 2009
    Inafield
    Just do as he said and it will be ok
    (I alway start and run the engine for about 1 minute without the chip in the dash, then refit chip)
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by electromech View Post
    Mate just do as the man suggests....cos thats how you do it ..It will not update from anywhere...
    Mar 2019
    Hi i know this post is quite old but is it possible i could grab some more info on the eeprom file i have read it into a hex editor but can not clearly see the millage any chance you could help with some more info or an i reading it with the wrong editor.. many thanks Les
    Mar 2019
    Sussex UK
    Hi did you get any more info. I'm trying to do the same, can read the eeprom but can't see any logic in the numbers displayed.
    clusters's Avatar
    Mar 2015
    Canada
    Post your file and someone can correct it for you.
    Edit: Never mind, saw your other post now.
    Please DO NOT PM me asking for help.
    Post in the forum, that is what it is here for.
    Mar 2019
    Sussex UK
    I now know how to sort it. Send a copy of the file and I will talk you through it. It took a lot of playing but I can now work out mileage from bin file and edit file to mileage required.
    Dec 2021
    Default are you still able to help work out the mileage
    Quote Originally Posted by Ace99 View Post
    Are you still able to help work out the mileage please, i can change the out put but not able to work out what i need to change to get an exact reading
  11. #11
    Mar 2018
    would you share this info with me please
