Results 1 to 15 of 16
    Sep 2018
    Greece
    Default Nissan micra k11 immo off
    Hello.
    The car is a nissan micra MY2000 k11.
    Ecu is 0261204247 with 93c46 eeprom.
    Trying to do immo off.
    Already tried immo decoding solution but it doesn't work.
    Car not starting at all.
    Tried a file with all zero's. Car starts and dies
    Tried al FF's, car not start.
    I disconnect the module next to the key.
    Is there another immo box in the car?
    I read that there is a module behind the dash.
    Any tested solution for this ecu?
    skens's Avatar
    Zagreb,Croatia
    hi
    fill out the profile correctly, there is no need to hide! read the eeprom and submit it
    regards
    Please dear members push the button thanks and reputation button(stars)
    do you need help? fill it in !!!
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    ECU type and number:
    Memories :
    https://www.digital-kaos.co.uk/forum...63#post1660863
    Sep 2018
    Greece
    Here is the ori file
    skens's Avatar
    Zagreb,Croatia
    hi
    good luck!!
    1 solution,remove immo box
    regards
    p.s
    Errors
    The following errors occurred with your submission
    • mk5gt has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    Memories :
  5. The Following 2 Users Say Thank You to skens For This Useful Post:
    Fenix Solutions (8th November, 2024), mk5gt (6th October, 2022)
    Sep 2018
    Greece
    Pm 's cleared
    When u say immobox u mean the module which is on the key lock?
    Sep 2018
    Greece
    When u say 1 solution what do u mean?
    Find the immobox, remove it and leave the eeprom contents untouched?
    The file u attached in your previous post is exactly the same with ori
    Nov 2016
    Default See this
    I have used this one...
  9. The Following 3 Users Say Thank You to notsku For This Useful Post:
    mk5gt (7th October, 2022), rob5 (15th November, 2024)
  10. #8
    Sep 2018
    Greece
    Already tried this file mate.
    Did the procedure u describe.
    Not working.
    Where was the immobox located in your car?
  11. #9
    Nov 2016
    I made couple of these cars with that ecu. I didn't touch immobox at all. I remember making that procedure with a key without chip if that makes any difference.
  12. #10
    skens's Avatar
    Zagreb,Croatia
    hi
    sorry, my mistake, here is the correct one
    regards
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    Memories :
  13. The Following 3 Users Say Thank You to skens For This Useful Post:
    mk5gt (7th October, 2022), newone (8th November, 2024), notsku (7th October, 2022)
  14. #11
    Sep 2018
    Greece
    FIXED!!!!
    The car started with skens file!!! Thanks again!
    For future reference.
    Disconnect the immo ring connector on the steering column.
    MAKE SURE YOUR BATTERY LEADS ARE CORRECTLY BOLTED.
    Convert the 93c46 eeprom file as below
    Pay attention to change only the first rows of the dump with 01's. Leave the rest as it was.
    Attached two photos of the ori and immo off dumps. I only changed the highlighted numbers.
  15. The Following 6 Users Say Thank You to mk5gt For This Useful Post:
    danielif (20th September, 2024), Kingur (2nd November, 2023), newone (8th November, 2024), notsku (7th October, 2022), Stelaras26 (22nd February, 2023), xseva (19th October, 2023)
  16. #12
    Nov 2016
    Do U have immobox attached on that immo ring or separate immobox near firewall?
  17. #13
    Sep 2018
    Greece
    It has a little box which is integrated with the ring.
  18. #14
    Apr 2024
    Hello, good morning, do you still have that file to share? Thank you very much.
  19. #15
    Dec 2024
    Me puedes pasar el archivo ?
