Results 1 to 6 of 6
    dd1's Avatar
    Aug 2014
    Default Mazda incode outcode calculation
    Hello everyone. I’m changing the ECM on this Mazda 3 and would like to get the codes for it. Posting the picture of the ECM outocode incode
    kiszka's Avatar
    Aug 2009
    Quote Originally Posted by dd1 View Post
    >> D1EF <<
    if there are problems, read old ecu eeprom and new ecu
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
    dd1's Avatar
    Aug 2014
    Thank you but is this enough? It only requires one part or maybe two piece of codes?
    kiszka's Avatar
    Aug 2009
    you gave me so much, so much you got, unless I have to add to you at random
    Reality of life :
    4:Everyone lies
    dd1's Avatar
    Aug 2014
    Quote Originally Posted by kiszka View Post
    I had posted the picture, and it had everything. All you have to do is calculate both, you did one only. It is ok. I have figured it out. The vvdi prog has the option for this calculation. Thank you
    kiszka's Avatar
    Aug 2009
    I'm sorry, but I misunderstood you because you wrote incomprehensible or the translation was distorted
    for this you turned the picture upside down, and I focused on the last code
    next time write I need two input codes ECU and Dash
    And this cannot be understood otherwise
    Reality of life :
    4:Everyone lies
