Page 1 of 2 12 LastLast
Results 1 to 15 of 25
    Jul 2017
    Default Winols 4.7 no pass and easy install
    Sharing winols 4.7 free and no password on rar file.
    Easy install instructions included and if you need help just write and i will help when i have time.
    This is nothing i have stolen from other forum, this is from then author of this crack/hack software.
    Instructions is made by me and if anyone has other solution or wounder anything, just write here in this thread or by pm.
    https://mega.nz/file/h9tVSYLK#QkhPAQ...kJs1PaUUoh2p5M
  2. The Following 20 Users Say Thank You to duckstar For This Useful Post:
    Adi202 (13th October, 2022), biela (13th October, 2022), blondu494 (30th March, 2023), Chimdhara (13th October, 2022), fanatic1992 (7th December, 2022), Iulyan13 (15th October, 2022), jenya (19th October, 2022), jfranchoza (20th April, 2024), karol123 (12th October, 2022), mkom82 (13th October, 2022), motocarlos (17th October, 2022), olegario (13th October, 2022), ombre57 (12th October, 2022), Pepesoft (13th October, 2022), PerturB (10th January, 2024), Sanyo320 (15th October, 2022), Tommeke (19th October, 2022), vinzzz34 (14th October, 2022)
  3. #2
    shendlaw's Avatar
    Jan 2022
    0x086
    Quote Originally Posted by duckstar View Post
    not working, got error
    Press thanks and rep button if i helped you
    * FILE SERVICE 24/7 *
    ECM TITANIUM - AUTOTUNER - DFOX - PCMFLASH - KESS - WinOLS
    TDI FOREVER
  4. The Following 2 Users Say Thank You to shendlaw For This Useful Post:
    dolarus (13th October, 2022), victorrav (9th June, 2024)
  5. #3
    Jul 2017
    Did you follow instructions? what OS are you running?
  6. #4
    Sep 2021
    i get this error
    If i helped you don't forget to thanks & rep
  7. #5
    Jul 2017
    Quote Originally Posted by kubaK View Post
    i get this error
    I think you did not run the 2YBWinOLS11.exe properly or it did not install correctly.
    Instead of running 2YBWinOLS11.exe you can download this .rar file and copy files inside to your WinOLS 4.7.4 installation folder.
    https://mega.nz/file/JlUGDDQb#sQnRAv...UJ4oqiIj3NldoQ
    And if you have any other installation of WinOLS on your pc it will cause problem.
    On one PC i had to reboot in safe mode and delete some evc .dll files inside C:\windows because of WinOLS asking for login window.
  8. The Following User Says Thank You to duckstar For This Useful Post:
    Sonyc (7th February, 2025)
  9. #6
    shendlaw's Avatar
    Jan 2022
    0x086
    same thing not working
    TDI FOREVER
  10. The Following 3 Users Say Thank You to shendlaw For This Useful Post:
    Brown012 (30th June, 2024), victorrav (9th June, 2024)
  11. #7
    Oct 2022
    I too have this error.
  12. #8
    Apr 2022
    witch OS does this work on..?, thanks.
  13. #9
    Jul 2017
    Quote Originally Posted by Ihyoen96 View Post
    I need to remote test one of you guys pc with this error to solve it, as i never got this my self.
  14. #10
    Jul 2017
    Quote Originally Posted by salahkebi View Post
    Windows 10 is only OS i tested on. Windows 7 should also work.
    Windows 11 i have to try.
  15. #11
    Sep 2021
    Willing to sacrifice safety of my machine send me pm. Still same issue.
    Only thought on why it might be failing is because i have windows home? not pro
  16. #12
    Jul 2017
    No sacrifice of any machine/pc keep in mind that i payed the chinese who made this hack 50 euro and let him control my machine/pc.
    Yes i think you need Enterprise or Professional to use this.
    I got same Login window popup on my machine/pc and the author of this hack told me he could not install it but i managed to fix it without him.
  17. #13
    Sep 2021
    Dear DK Users that are running into the same Licensing issue as i was, duckstar and i have come to a solution to this problem.
    The problem is that the Date & Time format needs to be set as: Year-Month-Day. Otherwise the WinOLS crack is not able to change the date properly causing issues.
    To fix this follow the steps below:
    1. Right click your date & time on your taskbar. (bottom right)
    2. Select "Adjust Date/Time"
    3. A Windows Settings menu will appear, On the top right hand side click "Date, time & regional formatting" under Related Settings
    4. Change "Regional Format" To "English (Sweden)" Specific country doesn't matter as long as format is YEAR-MONTH-DAY
    5. Enjoy WinOLS!
    If this helped please leave a thanks & rep for Duckstar and me!
    EDIT: Works perfectly fine on Windows 10 Home aswell.
  18. #14
    May 2021
    if you do not follow instructions carefully you will get errors
  19. #15
    Sep 2012
    I changed the date to YEAR, MONTH, DAY format and again the same error!
