Results 1 to 1 of 1
Threaded View
    Oct 2019
    England, London UK
    Default med9 audi a3 8P0907115K add s3 injectors and 3 bar map sensor
    I have this file for my personal car from a while ago (logged map), since then I've done more modifications I want to use it again because it has switchable pops and bangs via rear heater switch.
    I need
    S3 k04 8p Injectors added to it 06F906036F
    3 bar map sensor (if It's not already on there) 038906051C
    Or if you can add the switchable pops bangs via rear heater switch to the stage3 map
    Big thanks to anyone that can do it
    To help ive added
    My map on the car now with s3 injectors and 3 bar map sensor
    and original file
    If I helped, please consider hitting the Thanks & Rep buttons
