Results 1 to 5 of 5
    Newbie Autoelectricstw's Avatar
    Jul 2018
    Default CAS3+ change ISN
    Hi i have problem after my friend try add all key lost via VVDI tool now we can make ignition on car crank but dosnt start ECU edc17c50 log tampering fault
    anyone can change me Cas3+ isn code ?
    ISN from ecu is : FE23E43DAD68C5CF6D8E1CC359223DEC3
    ISN CAS3+ : B2 66 7A 71 E8 F6 89 8A F3 C2 59 AB DE 66 40 8F
    4D 99 85 8E 17 09 76 75 0C 3D A6 54 21 99 BF 70
    EGS-DME : D2 DB 81 10
    i need write isn to cas eep
    Aug 2012
    Abidjan
    Send flash ECU
    Oct 2011
    Croatia
    here is isn transfer,first key is not valid in cas....
    Quote Originally Posted by Autoelectricstw View Post
    try this and report
    kiszka's Avatar
    ISN is the same in ECU and in CAS no need to be replaced
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
