Originally Posted by
kasper1910
Hello Friends ,
I need help someone smarter than I.
I got my Fiat Doblo that have 2 programmed working keys. One of them is remote key but it not working. Seller told me that it worked but after battery discharged it stop worked.
I make dump from my BCM (Fiat OE 46817786). Inside was 93LC66 chip so I read it and decode pin code 27965.
I also buy another same BCM from Punto II and I reporogrammed it by this dump where I exta added one more key ( I prepared id48 transponder in Zedbull). So I get orginal BCM not touched and second one with added one key more.
After that I used multiecuscan for programming new remote keys and key. but I got problem. I cannot full read informations from BCM like hw, sw version etc. I only see ISO number 40 83 83 19 34. I am unable to program new keys I get unknow error. I tried on different version MES like 4.8, 4.6 , 4.2 etc.
I used Obdlink SX usb cable orginal !!!, elm327 bluetooth, cheap cable usb etc always I got these errors. I don't know what to do . Same errors on old BCM and new BCM programmed.
The strange thing is that I can check parameters, read and clear DTC errors, I can check in MES how many keys is programmed , how many Remote keys etc, everything work, but I can not add new keys and see full informations about BCM Delphi 188, that is in my car .......
Please help me what is going on, where is problem
