Results 1 to 12 of 12
    Sep 2014
    Default Help Iveco daily BSI Configuration swap
    I have Iveco Daily 2007 with
    MCU: 70F3238
    Eeprom: 95320
    I need help to clone it in new body buy in virgin state , if I swap eeprom contect not work ,the dashboard no work and the vehicle not start
    the original body computer was catching fire and damaged many tracks and components on the board
    Someone can swap configuration from old body to new?
    Pin vin,exc
    I have read, that in the eeprom 95320 there is an identifier number synchronized with the mcu
    kiszka's Avatar
    Aug 2009
    Quote Originally Posted by incutto88 View Post
    MCU: 70F3238
    Eeprom: 95320
    Pin vin,exc
    the new bcm eeprom is broken or virgin
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
  3. The Following User Says Thank You to kiszka For This Useful Post:
    incutto88 (23rd October, 2022)
    Sep 2014
    Quote Originally Posted by kiszka View Post
    she is a virgin, the body was bought at iveco
    the id identifier from mcu is the select 3 byte in pic?
    in my opinion this is the problem, the mcu is not synchronized with the eepromcompare ori new.jpg
    kiszka's Avatar
    Aug 2009
    these are two different BCMs, I think that no one can transfer the entire vehicle configuration here, the immo data alone could be transferred but if the BCM would be configured
    it remains to configure the whole vehicle with the diagnostic program after OBD
    then programming immo using
    pin pin is 56478
    Reality of life :
    4:Everyone lies
  6. The Following 3 Users Say Thank You to kiszka For This Useful Post:
  7. #5
    Jun 2012
    You have an incompatibility sw MCU <> EEP.
    This can be done without any problems. HW is compliant.
    It takes work time.
    Iveco only.
  8. #6
    Sep 2014
    pin pin is 56478
    with the new body computer mounted everything works except that the vehicle does not start, it would be enough for me that the immo data from the old eeprom have passed on the new eeprom,
    what do you recommend to configure the entire vehicle?
    thanks for the help you are giving me
  9. #7
    Sep 2014
    Quote Originally Posted by greyg View Post
    Hai un'incompatibilità sw MCU <> EEP.
    Questo può essere fatto senza problemi. HW è conforme.
    Ci vuole tempo di lavoro.
    hello teach me? thank you
  10. #8
    kiszka's Avatar
    Aug 2009
    check if this file is working properly
    https://mega.nz/file/RvxSFZja
    Reality of life :
    4:Everyone lies
  11. The Following User Says Thank You to kiszka For This Useful Post:
  12. #9
    Sep 2014
    if it works, I will pay you for the time you are dedicating to me
  13. #10
    Sep 2014
    Partial working after flash you file ,dashboard all ok,radio display code request, remote key fob only flash the hazard light ,after lock button press the all door remains open, in diag remain blank PIC VAN AND code configuration 20221023_134759.jpg
  14. #11
    kiszka's Avatar
    Aug 2009
    https://mega.nz/file/YvB0UYoJ
    Reality of life :
    4:Everyone lies
  15. The Following User Says Thank You to kiszka For This Useful Post:
  16. #12
    Sep 2014
    incutto88 has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
    Ok resend link
