    Dec 2014
    LOCATING
    Default R270 V:1.20 PROGRAMMER NOT WORKING
    Hi... Team..
    I have recently purchased one R270 programmer V 1.20. Unfortunately the hardware not detecting even after installing the drivers correctly.
    1. Port selection. Ok
    I suspect it is related to the Atmega32 flash/epprom related. So im requesting for Matmega32 flash/Eeprom & lock&Fuse bite informations to resolve this incident.
    Kindly supprort.
    Sanjeev
    Aug 2015
    turn ur anti malware off and try again and you might need to disable driver signature mode
    neuro's Avatar
    Dec 2010
    UK
    Quote Originally Posted by sanjeev View Post
    Hi... Team..
    Kindly supprort.
    Sanjeev
    did you put +12V to power up the programmer ?
    yes, I did connect the 12V power supply, still the same.
    dashradio's Avatar
    Inafield
    Sometimes depends on what Windows version your running, I only got it working on old versions
    Jan 2020
    Buy another, I have two, one that works and one that doesn't. Better buy another one and problem fixed
