What are the solutions beside Poldiag and VVDI2 with sync file from 3rd parties?
With VVDI no need to buy sync file from 3rd party. But seems to be a hard work. Never did it, but I would like to test it. Reading ECU and ELV is no problem. But ecu needs to be bosch EDC/MED17. Of course dealer key and learn it only with bcm2 file or online is an option, too...
Greets MR...
But if I think about this VVDI2-option to generate A6 4G AKL: What is with the gearbox? ShouldŽnt be the sync file for calculation of TCU CS, also? Maybe this procedure works to generate key, which unlocks ELV and start the engine. But maybe the TCU still will be immobilized!? You should try to find someone, who tested this procedure on automatic car I think. IŽm out, never did this. To much work, buy a dealer key would be cheaper as this work and pain in the head. Here in germany dealer key 224,50€ + Tax. Would get some percent discount. This procedure only could be profitable on stolen car, but this is not my business.
Greets MR...
avital (2nd November, 2022)
Not necessary for stolen cars.In my country if your car is not registered here you cannot geta dealer key. If you just bought your car and you have a tempoprally plate, you cannot get a dealer key.
Or you are a tourist and you lost you single key. You mus wait for 10-15 days in order to get key.
rm23 (30th October, 2022)
No other solutions. Without synch file nogo. That vvdi shit reading dumps from bunch car modules wont work
If have all files from bcm2,ecu,tcu and elv sync can be calc
Please take in to account that a lot of such car dont have ELV.
Not important elv, sync can be calc without elv data if car not have, but need tcu and ecu files.
Tcu store immo data like ecu, need read flash and eep and data can be calc aftre.
p1et (2nd November, 2022)
