Page 1 of 65 1234561151 ... LastLast
Results 1 to 15 of 967
Thread: RCD 510 codes.
    einet's Avatar
    Default RCD 510 codes.
    IHAVE 2 vw RADIO RCD510 SYSTEMS
    they are from blaupunkt and has the same part number
    815 7 647 239 360
    serial of first unit is VWZ1Z314213773
    serial of second unit is VWZ1Z3H3335727
    i hope you can generate the pin code of the units
    thanks for your time
    The code for
    VWZ1Z3142137737647239360 are 0562
    VWZ1Z3H33357277647239360 are 0056
    einet
  2. The Following 14 Users Say Thank You to einet For This Useful Post:
    ahmet1873 (12th June, 2022), asliyucegsm (15th April, 2020), Baltazar31 (21st October, 2018), dragoshu (28th March, 2018), fathizizou (8th June, 2020), helper33 (8th June, 2020), julio cesar 27 (24th December, 2017), maher1800 (6th September, 2018), mido007 (29th December, 2018), moartea1998 (11th June, 2023), MOBILTRONIC (27th September, 2017), serboyi (25th December, 2019), sinanbuyukkutuk (23rd February, 2018), yunuselektronik (30th November, 2023)
  3. #2
    Thank's this says to me that you're code generater is working!!
    Because i've get the 2 codes from vw today.
    They are exactly the same.
    Thank you very much!!!!
  4. The Following User Says Thank You to rabbit72 For This Useful Post:
  5. #3
    Junior Member ellvis's Avatar
    i think there is no calculator !!
    only access to database from VW !!
  6. The Following User Says Thank You to ellvis For This Useful Post:
  7. #4
    Stoyko's Avatar
    Bulgaria
    I'm sure to every good decoder can decode this unit , Elvis !
    And after him decode , dielers can smook otside
    Wbr from Bg.
  8. #5
    murat332's Avatar
    Türkiye
    Smile hi my friend einet
    Quote Originally Posted by einet View Post
    einet
    please need code for my radio rcd510
    RCD510
    VWZ1Z3I42447903C8035
    Thanks in advance
  9. The Following 2 Users Say Thank You to murat332 For This Useful Post:
    branco1 (17th June, 2018), fathizizou (8th June, 2020)
  10. #6
    Quote Originally Posted by Stoyko View Post
    Wbr from Bg.
    some decoder can change code in factory-modus !!
    but i know nobody that can give correct original code without VW-database. !!
  11. #7
    Stoyko's Avatar
    Bulgaria
    Agree , but I know few peoples who decode some of these by method "test all codes one by one"
  12. #8
    yes that is the only solution for now what really works.
    and why ?
    because there is no calclulator for VW since many years.
    and after customers changing the algo nobody can calculate from dump.
    is the same like old navigation MCD or MFD, RNS the ****...algo was never encrypted only solution for these model are changing code lines and code in dump.
    On new navigation and carradios the customer make this solution off.
    regards
  13. #9
    Stoyko's Avatar
    Bulgaria
    Quote Originally Posted by ellvis View Post
    regards
    Here have one man who can extract code from these......
  14. #10
    Car235's Avatar
    Where einet read code, it is not important.
    It is important that we have here on the forum man, who can help...
    Maybe einet is a good dealer who can to help, perhaps a hacker .... Maybe clairvoyant ....
  15. #11
    Default CODE RCD 510 HELP
    IHAVE 1 vw RADIO RCD510 SYSTEMS
    815 7 647 239 360
    serial of first unit is VWZ1Z3H3369431
  16. #12
    Hi this mensagem for Einet
    815 7 647 239 360
    serial of this unit is VWZ1Z3H3369431
  17. #13
    einet's Avatar
    Hi @ ALL,
    I only give RCD 510 codes for users that contribute on the forum and have more that 20 posts and 5 thanks!
    einet
  18. The Following 5 Users Say Thank You to einet For This Useful Post:
    fathizizou (8th June, 2020), marcoane (15th June, 2023), Omaro (17th September, 2019), paulitu (7th June, 2023), serboyi (25th December, 2019)
  19. #14
    murat332's Avatar
    Türkiye
    Hi @ ALL,
    einet
    hi friend
    Please need your help
    regards
    Quote Originally Posted by murat332 View Post
    RCD510
    Thanks in advance
  20. The Following 3 Users Say Thank You to murat332 For This Useful Post:
    branco1 (17th June, 2018), serboyi (25th December, 2019), tibtij (25th November, 2014)
  21. #15
    einet's Avatar
    Hi Murrat
    your code RCD for serial 42447907647239360 are 0363
    einet
  22. The Following 10 Users Say Thank You to einet For This Useful Post:
    Alawigmx (12th April, 2019), dragoshu (28th March, 2018), kappa1 (13th December, 2017), KillMe3 (13th April, 2020), murat332 (7th September, 2022), proscar (19th March, 2020), serboyi (25th December, 2019), yunuselektronik (30th November, 2023)
