Results 1 to 11 of 11
    Member bawbag_'s Avatar
    London
    Default pp2000 ecu configuration problem
    Hi All, I'm back with another pp2000 problem. I have just fitted a new factory ecu to a 2005 206. Engine runs fine but I am having issues configuring ecu and as a result the ecu has a permanent fault code for configuration. I am unable to read configuration from old ecu as it is dead, burnt board. automatic configuration ends with connection fail as does manual configutation for which I am guessing correct options.
    MIL is on.
    Old ecu was sagem, new ecu is valeo.
    As usual, any input would be appreciated.
    vin VF32AKFWF44493534
    eng code KFW
    AUTO ELECTRICIAN, CITY & GUILDS QUALIFIED.
    30+ YEARS EXPERIENCE.
    OLD SKOOL SPARK
    (now retired)
    Junior Member Bento16's Avatar
    Hawaii
    If you have a Sagem fuel injection you cant install a Valeo ecu........
    Only Sagem it will work.
    Probably you by a wrong ecu.
    The ecu part number that you need is 1939V8
    DK Veteran MOBILTRONIC's Avatar
    Bosnia & Herzegovina,Cazin
    Try working order as you search sw.Example, cooler fan motor, how many and how much speed, check, type ,verify and writte in sw,Coding of injectors;look number on injectors and writte in sw and so order.
    London
    Quote Originally Posted by Bento16 View Post
    Peugeot parts and their help department in France have assured me thast this is correct replacement for the Sagem S2000 which is no longer available.
    OLD SKOOL SPARK
    (now retired)
    Quote Originally Posted by MOBILTRONIC View Post
    It's gasoline engine, mate, not diesel...
    Anyway, please post here VIN and I will try to help you.
    London
    Quote Originally Posted by alexs307 View Post
    Gasoline engine
    OLD SKOOL SPARK
    (now retired)
    OK, not diesel,this is example.How many see some things must be draw.I look,worse man than he who helps where help is required.
    Quote Originally Posted by bawbag_ View Post
    Gasoline engine
    Sorry, but I can't find any 206 with Valeo ECU to retrieve coding. All of them are J34P.
    DK Veteran cars's Avatar
    Italy
    Have you tried changing the index "built-in system interface", because this type of 206 has the CAN bus as a communication system and not common wire connection.
    Member PAB's Avatar
    Somewhere
    As fas as i know...the automatic tele.. will not works !!When you a dealer.. the tool will make connection to internet and will loginto mainserver he reads the vinnumber when you did fill in. At that time he will configure automatic.
    When you not a legal dealer.and have the un-legal tool...you must do all by hand..
    i had to reprog a BSI from 307 SW by hand..had to look into all submenu's and did check what the car had..and not..like "make-up mirror ?? yes no ?.. all things like that.. after that reprog keys..ECU did get free..then you can reprog ECU...( need pincode )..it worked by me.
    Wish you good luck..but think it can be done.
    London
    Thanks for all your suggestions, my client took the car to the main stealer and got them to configure it,
    OLD SKOOL SPARK
    (now retired)
