Results 1 to 5 of 5
    Nov 2018
    Default Renault espace 2,0 dci error df121 after flash
    after flashing dpf and egr its showing error DF121 and the car is not going more than 1300 rpm?why?
    Thanks for the answers and with regards!
    qni666's Avatar
    Mar 2019
    Bulgaria
    with automatic doftware was remove dpf,egr or manual ? upload files here to see
    WANT PASSWORD ? PRESS THANKS AND ADD REPUTATION AFTER THAT CAN ASK ME PASS PM
  3. The Following User Says Thank You to qni666 For This Useful Post:
    nikotina1 (7th November, 2022)
    gwiazdamb's Avatar
    Aug 2022
    PL EU
    Quote Originally Posted by nikotina1 View Post
    Often occurs after flashing check the injection codes or
    There are 2 types of heater plugs on this vehicle (fast and slow heating) you need to configure the heater plug type to clear this fault code.
    This is usually in the engine ecu commands menu
    black ring around the glow plugs = configure as slow heating
    White ring around the glow plugs = configure as fast heating
    Use CLIP
    PLEASE PRESS THE " THANKS " BUTTON
  5. The Following User Says Thank You to gwiazdamb For This Useful Post:
  6. #4
    Nov 2018
    Hello,thanks for reply.
    I will try tomorow with clip while I am using launch and its not possible to do this.
    Nov 2018
    With automatic doft was deletet.
