Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Hybrid View
    Mar 2019
    Scandinavia
    Question Toyota Corolla transponder
    Hi, I am struggling to find correct transponder for Toyota Corolla 2008 /E150. The car have ordinary key but customer says it had remote for doors.
    All Keys Lost and I've already fixed key code and have cut the key. Key is okay and turns on IGN.
    As I understand, it should be DST80 bits G-chip from 2008 - 2014.
    Someone on this valued forum who have some experience with Toyota keys?
    Looking forward for any suggestions!
    learning by doing, learning by experience... please thx is I helped you
    Aug 2014
    Tripoli-libya
    2008-2010 is 4d67 2011 -2012 id G
  3. The Following User Says Thank You to alhengary For This Useful Post:
    Willinickersen (6th November, 2022)
    Mar 2019
    Scandinavia
    Quote Originally Posted by alhengary View Post
    Okay, this show other
    Aug 2014
    Tripoli-libya
    its 4d67 but to make sure send vin
  6. The Following User Says Thank You to alhengary For This Useful Post:
  7. #5
    Mar 2019
    Scandinavia
    AHTLB56E003023593
  8. #6
    Aug 2014
    Tripoli-libya
    use 4d70 >>>>>>>>>
  9. The Following User Says Thank You to alhengary For This Useful Post:
  10. #7
    Mar 2019
    Scandinavia
    use 4d70 >>>>>>>>>
    I have tried to make key with 4D 70 and I have tried to log in with XTOOL X100 pro2 without any success too... No connection... I belive immo box is locked?
  11. #8
    super jumbe's Avatar
    Dec 2008
    Livingstone
    I had similar issue with Avensis 2009 tried every trick had to remove dash and remove immo box and wrote virgin dump with 4D70 worked, you need someone with Corolla virgin dump.
  12. The Following User Says Thank You to super jumbe For This Useful Post:
    Willinickersen (7th November, 2022)
  13. #9
    Mar 2019
    Scandinavia
    Thank you very much
  14. #10
    ray-ray's Avatar
    Nov 2009
    It a dot key, do a battery reset. After reset do 4-13 for 35 min. Grounding the obd2 dash should flash red,green,and yellow. After that you should have communication.
  15. The Following User Says Thank You to ray-ray For This Useful Post:
    Willinickersen (9th November, 2022)
  16. #11
    Mar 2019
    Scandinavia
    Quote Originally Posted by ray-ray View Post
    Thank you very much for your answer!
    Not sure what "dot key" is...
    The battery have been "dead"..not sure other way to have reset the battery .. I will try to jump OBD PIN 4-13 for 35 min.
  17. #12
    Dec 2008
    Livingstone
    I tried OBD PIN 4-13 for 40 min did not work just do as I said on page #8.
  18. The Following User Says Thank You to super jumbe For This Useful Post:
  19. #13
    Mar 2019
    Scandinavia
    Quote Originally Posted by super jumbe View Post
    Thank you again for answering! I will try to remove immo box
  20. #14
    ray-ray's Avatar
    Nov 2009
    First generation (4C) no marking on the oem blade 1997-2003
    second generation (4D) there a dot marking on the oem blade 2004-2011
    third generation (G-72) there is G stamp on the oem blade 2012-2017
    four generation (H) there a H stamp on the oem blade 2018-present
    these list is for the USA region, note there a few models that are behind ie: 4runner
  21. The Following User Says Thank You to ray-ray For This Useful Post:
  22. #15
    Mar 2018
    UK
    This one for sure is 4D70 so take out the dash and do the key on bench - No need virgin dump
    don't waist your time by OBD
  23. The Following User Says Thank You to Manta1600 For This Useful Post:
