Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    Jul 2011
    Delete and re-program both owkring key and new key , remote will work properly , i did it many times by Zed-FULL
    NOTE : Please make sure of Remote key, if it is chinese , chip must be on board - seperate chip will not work
  2. #17
    newone's Avatar
    Oct 2016
    Quote Originally Posted by baken View Post
    chinese key(seperate remote) allready worked for him with manual procedure,he posted results
  3. #18
    work with new chinese key.
    (and original work too.)
  4. #19
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by newone View Post
    there is a manual procedure for that
    lock car with original key
    unlock mannualy with blade untill window down
    open door put original key in ignition and turn on
    close door
    put new key in driver door
    turn to unlock press and hold unlock
    turn to lock press and hold lock
    hazard light will flash
    remove key from ignition
    ready
    tested by me same key and worked
    I am little bit confused about those steps, can you explain it better? Do we have to:
    First Press and hołd unlock and then turn key to unlock or turn to unlock and Press and hołd remote unlock button while keeping key turn to unlock position?
  5. #20
    newone's Avatar
    Oct 2016
    hi p1et,turn key to unlock position and while keeping it in that position press unlock,like that and the other stages
  6. The Following User Says Thank You to newone For This Useful Post:
    p1et (22nd May, 2024)
  7. #21
    p1et's Avatar
    Oct 2013
    Perfect, it is working!
  8. #22
    Jun 2020
    Fantastic helped me with my remote A1 km100 would not learn the remote But now thanks to your post it is now working
