Results 1 to 15 of 22
    Default Audi A1 2014 year remote learning
    Here is Audi A1 2014 year.
    Original key = 8X0837220D
    Original key working good. (start the engine and remote is working too.)
    I would like to add plus one key.
    I order same 8x0837220d key from china. I check it, same transponder, same frequency.
    I can learn key with original VVDI2 / original Smok / FVDI (abrites clone).
    I tried all of them.
    Every devices can learn the key, but remote function not working on new key.
    I search the problem lot of time in google, here, but I didn't get answer. VCDS not have function learn remote seperatelly. After learn key , none of these devices ask me press button. So I don't know, how learn remote. (because transponder is seperatelly in this key.)
    Maybe this chinese key not work? should i buy a factory one?
    (but then there is no possibility after teaching to press a button and I doubt that he would learn it without it.)
    My friend tell me maybe FVDI newest version have remote learn after learning key. But only V38.1 version, but I have V18 and V24 on fvdi, if I choose V38 then special function not active. How can I activate it? (maybe this version can..)
    So what is the solution?
    I have VVDI2, smok, fvdi, vcds, etc..
    Please help me!
    Apr 2019
    Abrites AVDI can do this, but you have to add the key from special function "Can instrument" and press the button in the right corner when you are done. I to spent a lot of time finding this option thinking it was something wrong with new keys but it was not. This button is not mentioned in the manual and you do not get this option from wizard or standard keyprogramming option.
    If you are in the car key bussiness then I recommend you to buy OEM program from AVDI and not pirate copys from China, then you contributes to the development of tools that we all need in this line of business.
    p1et's Avatar
    Oct 2013
    Forget it, you have bad key, it will never work with this model. That's a little tip
    I agree, my job is car electronics, key copying is still a bit new, but unfortunately a lot of people in the area work with Chinese instruments. I have original Bosch KTS, original Launch, original Wow, original Smok, original Carprog (these are already several tens of thousands of dollars), VVDI2, etc., I can do most things with these instruments. Abrites is unfortunately a clone. I will probably buy an original after this.
    but until then is there no solution? the customer is waiting..
    My problem my abrites clone I don't find this function.
    I attached photo.
    This is V24 version.
    Can you attach photo what button missing here?
    Maybe only V38 version know this?
    V38 special function is not active for me..
    does anyone know of a solution before the original abrites arrives?
    Can I download crack for this? Thanks.
    super jumbe's Avatar
    Livingstone
    Did you check the frequency on both keys?
    Quote Originally Posted by super jumbe View Post
    yes, same.
    Livingstone
    Quote Originally Posted by bendix2 View Post
    yes, same.
    Chinese keys I would keep away on latest model cars faulty key pal try good supplier.
    Dec 2010
    Nottingham
    1st is your key intergrated chip or is it seperate chip and remote board ?
    2nd is the key genuine or chinese ?
    your clone screen is a very old clone and does not have the required button to complete remote coding
    buy original avdi if you want to use avdi functions or search for a different tool that can do these
  9. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    bendix2 (8th November, 2022)
  10. #9
    1. seperate chip and remote board
    2. chinese (I think I will buy original key, but I don't have this function, so I think I can't learn original key remote too.)
    Thanks the photo. VVDI2 can not do this?
    And what I need buy?
    flyobd.com is original, or good for this?
    or only from abrites.com?
    (Or can I download this version for my clone fvdi? before original comes. because it is very urgent :/)
  11. #10
    Dec 2010
    Nottingham
    i dont use the clone , i use original abrites so cant answer your question on whether another fvdi version will work or not , id be surprised if vvdi couldnt do it but as i have abrites i dont have vvdi so cant answer if it does this .
    personally i wouldnt trust the clone on these .
    if chinese and seperate chip then your on a hiding to nothing
  12. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    chapp (23rd May, 2024)
  13. #11
    newone's Avatar
    Oct 2016
    there is a manual procedure for that
    lock car with original key
    unlock mannualy with blade untill window down
    open door put original key in ignition and turn on
    close door
    put new key in driver door
    turn to unlock press and hold unlock
    turn to lock press and hold lock
    hazard light will flash
    remove key from ignition
    ready
    tested by me same key and worked
  14. The Following 12 Users Say Thank You to newone For This Useful Post:
    bendix2 (9th November, 2022), chapp (23rd May, 2024), Faraday (9th November, 2022), Manta1600 (9th November, 2022), mjoesen (23rd May, 2024), musti418 (9th November, 2022), p1et (22nd May, 2024), Raould (24th May, 2024), tepSIJA (24th May, 2024), vialli (9th November, 2022), wuza (9th November, 2022)
  15. #12
    Quote Originally Posted by newone View Post
    close door
    ready
    Thank you very much, it's work!!!
    I am very grateful, you have saved me a lot of time.
    Anyone has a similar problem this solution really works!
  16. The Following User Says Thank You to bendix2 For This Useful Post:
    p1et (14th November, 2022)
  17. #13
    auto techniek's Avatar
    Mar 2017
    Did it work for original key or new chinese key?
  18. #14
    Apr 2022
    Germany
    @ bendix2
    just checked the svci 2019 and VAG 37.0 version...
    In option VDO/ NEC 2009+ there is this small window down on the right side...
    I can’t confirm if it is working or not...
  19. #15
    Livingstone
    Quote Originally Posted by auto techniek View Post
    Original key works without programming.
  20. The Following User Says Thank You to super jumbe For This Useful Post:
    auto techniek (15th November, 2022)
